Plex Media Server not picking up new content in my libraries
@ChuckPa said:
Oh? Were this a Synology box, I would immediately have you double check the plex user has permission to access the specific shares. Synology is famous at forgetting. What happens is some of the library works while other parts don’t. They use ACLs and not real Linux permissions. If you get into the NAS, set file permissions at the Linux level, the whole problem is gone forever.
Yes, it is a Synology.
So I am clear, You assert a Library friendly name of ‘This-Library-Section’ does not work where ‘ThisLibrarySection’ does work or do you mean this as it relates to the directory name used on the NAS?
Yes, you understood it correctly.
I have only used the Synology-tools so set my partition where I have all my media as a shared folder, never tried the Linux command line way.
Thanks for your willingness to help.
@ChuckPa,
I’m not a technical person at all but did what I could to understand and do the tests what you mentioned. Not sure if I did it right but I’ve attached the info. So how did this happen anyways? I certainly did not mess/change with any settings on my end. PMS was working fine then suddenly it wasn’t. I can’t even delete a library.
So I tried it again - deleted PMS completely. Ejected my hard drives. Downloaded PMS again and lo and behold my entire library was there (even tho I had not re-connected my hard drives). Still with the same issues.
Please help…
Just downloaded the latest update with great anticipation but alas…PMS still having the same issues.
@ChuckPa - any insight into the files I uploaded?
Yes, I’ve had time to learn more about Enterprise class LAN management and did get a chance to look at a few things.
Would you please go to www.ipchicken.com and take a screen shot of your IP?
Also, please go to your modem and look at the WAN IP address.
Then please PM me those results?
Ok so good news for anyone facing the same problems as I did. Turns out that on iOS (not sure about Windows or any other operating system) simply deleting PMS from the Applications folder is not enough. You’ll need to go into Library and delete everything PLEX (PMS folder under Application Support) there as well to completely get rid of it. Once this is done, clear your trash, then download the latest version of PLEX and then start adding your libraries to it again.
New content not appearing and library scans seem to running constantly.
Plex Media Server Logs_2019-02-28_14-14-46.zip (3.4 MB)
For the last 30 days or so, plex would not “see” the new files in some of the folders. It sees them in others, but not all. If i move the folder to another drive… then it sees them again. I can move it to the original location, and it will see them again. but just scanning the library does not show them in there. This is happening to about 1% of the folders, but its very annoying.
I ran into this recently and was able to fix it by editing the library and re-aiming the folder path.
I’m using a QNAP TS-469L, and I had recently disabled the Logitech media server.
Everything went nuts on some, but not all PMS libraries. The libraries which were misbehaving were the default folders (TV/Movie) which were preset with the Logitech server in their media path. Changing this to a more manageable direct file path resolved my issue.
Hope this helps.
Hi, i just had the same issues and resolved by editing the library and adding a new folder to same library. That seems to make Plex review all the existing foldering properly and discovered all the missing items straight away. Then i removed the additonal folder from the library and all good.
Cheers
