Plex Media Server - Synology DSM 7 Preview - Issues ( Archive )
@drracing07
Please read the top of this thread AND the instructions.
That it will upgrade automatically through package center? Looking for a way to get that kicked off.
fixed
Got it working. Turns out I’m a dingus and used the wrong package download. Installed, migrated and verified everything is working as it should. Thanks!
Here are the logs. I cannot seem to edit the post and add the attachments. (File removed)
@Darkrogue
It wants to burn ASS subtitles.
  1. HW is disabled when burning subs.
  2. It can’t find your hardware. Which firmware version?
seems that my “old” installion will not recognized. Starting local forced adding a new server with the same name but with no libraries :frowning:
Working great here on a DS1621+ w/DSM 7 Beta. Followed the instructions regarding the permissions, and away it went.
Working great here also - I have a question. I used to back up the Plex Databases folder using HyperBackup but they are tucked away in. @apphome now. Is there a recognised way to secure these or am I being paranoid.
Thanks.
@noyse
Did you follow ALL the instructions about granting permission for the NEW username PlexMediaServer to have access to read your media?
@hippotech
They are in @apphome. This is what Synology wants in DSM 7.
The WHOLE world changed in DSM 7.
I am working on all the extra bells * whistles – which include backup, restore, etc.
FIrst, I need survive the beta.
Thanks for the quick reply and thanks for pulling out the stops on this.
A question if I may?
How do you all like the new GUI and feedback for install, update, & uninstall ?
Followed the instructions and changed permissions. Installed again without errors. One thing I did notice is the need to be patient during the final phase as mine sat at “Updating …” for quite a while before it finished.
For me it helped a lot as I made a mistake first time through and it explained the issue for the rerun.
@AustinTX
While the move is immediate, DSM performance is based on NAS CPU.
yes i did
@noyse
Have you, at any point, used FileStation or the command line, to manually set ownership or permission inside the Plex shared folder?
hi! can anybody help me? after update to 7 version I can’t use Plex
@SkySpirit
Go to the top
Download the correct DSM 7package.
You still have DSM 6 Plex installed.
