Plex Media Server - Synology DSM 7 Preview - Issues ( Archive )
Hello all,
I have "successfully"upgraded my synology DSM 7 and can run plex just like before. However, I noticed something tonight after adding a new movie in the movie folder and a season of a show in the TV folder. They have the usual proper naming conventions like everything else, but they will not show up, in Plex. I see them in the folders just fine. Everything else that was in those folders from preDSM7 shows up and plays, but nothing I do will make the movie or tv episodes (that are added since upgrade) show up to play. Anybody else having this issue?
@mdp123
Did you follow the instructions on that final popup?
I just thought that a hard reset and a fresh install would work. I don’t care to save the old libraries. Still when i open my multimedia files it shows me the link to the download page of plex, but I’m on my http://ip.addr.of.syno:32400/web .
Worth to mention i’m not in the same network of my nas, my url is not the usual 192.168.1.xxx:32400 but a random ip from my provider. Maybe it’s a dns problem ? Thank you
@raoh980
Now you get to use the new feature I added to the DSM 7 packaging -
Install using Plex Claim Token
I created this ability for all those awkward times like this.
  1. Uninstall the DSM 7 package you have with the KEEP option
  2. Install again using the Plex Token.
If it is of help, the package supports English, French, Castilian, German, Dutch, Danish, Korean, and Chinese. Switch the DSM language and the package will detect the language.
So will this let me get my libraries back or am I basically SOL?
I needed to do a fresh Plex install on my Synology DS218+ running DSM 7-41890. Every time I try to install the package I get the following error. I’ve downloaded the most recent version, for ARMv7 for 18 series. But nothing works. Any advice?
@StevenF19
Steve,
If the only thing wrong here is that the server got disconnected from the account (a variety of reasons), this will bring it back.
If you’ve done something to reinitialize the database – well, then you will be rebuilding to some degreee
@pwsteinke_gmail_com
go back and check what you downloaded.
either:
  1. Wrong DSM version (look for the (dsm7) tag on the files)
    -or-
  2. Wrong model.
You need the Intel 64-Bit File for your NAS
Followed all the steps but I don’t see my libraries anymore. So annoying. My plex folder is still there and has data in it. But it never prompted to migrate anything. I tried the script in Task Scheduler (posted above) and get the error: cannot access ā€˜volume1/@apptemp/PlexMediaServer’: No such file or directory
Hello there !
I have followed your instructions. erased Plex from DSM6, restart DSM 7. Then, I have downloaded the ARMv7 ( I have a NAS DS 415 Play ) and after few seconds, it shows the message :
This package is not supported on the platform of Diskstation or is incompatible with the current DSM version.
I am stuck here. Cant go further. There is no PLEX shared folder installed. Nothing, in fact, is installed. I have, of course, checked the current version of DSM7. It is updated to DSM7-41890.
A little help ?
Thanks for the incredible work.
Love from France,
Gilles
@bkays
DId you uninstall the DSM 6 package first ?
From all you’ve stated here, it sounds like you ā€œupgradedā€ which is not how the migration procedure instructs. In the initial packaging (what you have now),
  1. Uninstall the DSM 7 package & Erase (so it’s not confused)
  2. Now install the DSM 7 package.
  3. It will migrate
@GVautier
  1. It’s an X86 Evansport - Not an ARM
DS415play	Intel Atom CE5335	Dual Core	4	Yes	Evansport	DDR3 1 GB
Yes I did. I have tried this many times now and no success. Have uninstalled DSM 7 package now multiple times using all options. I reinstall using the Claim token and it prompts me to create a new server and add libraries as a new server.
Aaaah, ok…
So, I must erase all my datas ? My movies and TV shows ?
I just read your last message. Did I downloaded the wrong package ?
And thanks for the speed of the answer…
@bkays
Can you please get into the ssh shell? I think I know what is happening.
There are some users who’ve had Plex for so long that the shared folder is named /volume1/plex and not /volume1/Plex
Not catching that was both a DSM 6 problem and my oversight.
I can help you migrate now because the new packaging expressly looks for more of those rare combinations.
Care to try ?
OK. Let’s try. Very nice from you to help me…
@GVautier
Download the correct package and begin installation.
Sure would love to give it a try thanks!
Which is ?
Sorry… :pensive:
