Plex media server won`t launch
Server Version#:
i just installed plex medis server but it won`t launch
Are you using the 32 or 64 bit Windows version? Is this a first time install on this machine or was it on there before? If it was on it before a corrupt database can cause it not to launch in which case you can try to restore a database backup
64 bit first time install
Can you check if is is creating any server logs
How are you trying to open the server?
What do you get when you click this link?
http://127.0.0.1:32400/web
I am having this same issue. 64 bit Windows version. New computer. I’ve installed and uninstalled several times. Nothing helps. When I click that link I get the Plex web app.
