Plex Media Server
Plex Media Server 1.21.1.3753 is now available to PlexPass users in the Beta update channel.
NEW:
  • (Transcoder) Add support for the Intel Compute Runtime OpenCL driver versions 20.36 and later for newer integrated GPU models on Linux
FIXES:
  • (DVR) Plex Tuner Service would sometimes fail to start up on Windows, when machine was under load (#12035)
  • (Library) Studio would be listed twice in custom filters (#12124)
  • (Pivots) Only display playlist pivot if it is non-empty (#12097)
  • (Scanner) New movies would have incomplete metadata if the scan was invoked from the command line (#12156)
Plex Media Server 1.21.1.3759 is now available to PlexPass users in the Beta update channel.
NEW:
  • (Hubs) Seasonal and Event based hubs (Generated locally. Can be toggled in Library settings)
FIXES:
  • (Scanner) Rare crashes when scanning in duplicates
Plex Media Server 1.21.1.3766 is now available to PlexPass users in the Beta update channel.
NEW:
FIXES:
  • (Hubs) Seasonal hubs could cause text overlap in Plex Web
Plex Media Server 1.21.1.3766 is now available to everyone.
Plex Media Server 1.21.1.3795-ee64ab56f is now available to everyone.
NEW:
  • (Web) Updated to 4.47.3
Plex Media Server 1.21.1.3830-6c22540d5 is now available to everyone.
FIXED:
  • (DVR) Require postal code during setup for Poland, Russia, and Switzerland.
Plex Media Server 1.21.1.3876 is now available to everyone.
NEW:
FIXES:
Plex Media Server 1.21.2.3918 is now available to PlexPass users in the Beta update channel.
NEW:
  • (DVR) Server will scan a media item, or library contents, for commercials when “Analyze” is invoked (#12059)
  • (Library) Enhance smart shuffle to do a better job of feeling random.
  • (Web) Updated to 4.48.1
FIXES:
  • (DVR) server would sometimes re-record shows that already existed in library, but were slightly smaller due to custom postprocessing (#11689)
  • (HTTP) The server could crash when setting up libraries during first run.
  • (MUSIC) Changed played progress point for podcasts/audiobooks to 99%, other audio content to 50% (12193)
Plex Media Server 1.21.2.3939 is now available to everyone.
NEW:
  • (Gaming) Retro Games with Plex Arcade sub (MacOS and Windows)
  • (Web) Updated to 4.51.1
FIXES:
  • (EPG) Some hubs were empty or missing items after transition to Gracenote. (#12229).
  • (MUSIC) Changed played progress point for podcasts/long-form-audio to 99%, other audio content to 50% (12193)
Plex Media Server 1.21.2.3943 is now available to PlexPass users in the Beta update channel.
FIXES:
  • (Agents) TheTVDB Agent matching could fail in some cases (#12295).
  • (Scanner) Fixed regression causing excessive library scan times in previous release.
Plex Media Server 1.21.2.3943 is now available to everyone.
Plex Media Server 1.21.2.3978 is now available to Plex Pass users in the Beta update channel.
This update contains internal changes in support of upcoming server functionality improvements.
Plex Media Server 1.21.2.3997 is now available to Plex Pass users in the Beta update channel.
FIXES:
  • (TLS) Fixed an issue that could cause TLS certificates to be renewed prematurely
Plex Media Server 1.21.3.4015 is now available to Plex Pass users in the Beta update channel.
Plex Media Server 1.21.3.4014 is now available to everyone.
FIXES:
  • (Security) Mitigate against potential DDoS amplification by only responding to UDP requests from LAN
Plex Media Server 1.21.3.4021 is now available to Plex Pass users in the Beta update channel.
FIXES:
  • (TLS) Custom certificates were not used in some cases where they should’ve been
  • (TLS) Improved error handling and logging
Plex Media Server 1.21.3.4021 is now available to everyone.
New certificate generation is now available to a limited number of Plex Media Server users on versions 1.21.3.4021 and later. For further details, and to opt-in to early access, see this thread in the Plex Media Server forum.
Plex Media Server 1.21.3.4046 is now available to Plex Pass users in the Beta update channel.
FIXES:
  • (Gaming) (Windows) Add firewall exception for game transcoder.
  • (Gaming) (Windows) Fix games not being copied over to app support.
  • (Gaming) (Windows) Fix hang stopping game.
  • (Gaming) Correctly bind analog triggers.
  • (Gaming) During library creation, kick off MAME core download.
  • (Gaming) During library creation, move over new skeleton core mapping file.
  • (Gaming) Exit if we fail to submit frames to Parsec.
  • (Gaming) Fix for crash in a few cores (e.g. mesen).
  • (Gaming) Fixed scaling with games which change resolution (e.g. Tekken 2).
  • (Gaming) Pass back better errors when game transcoder exits at start.
  • (Gaming) Redirect joypad to keyboard for MAME to fix e.g. Asteroids.
  • (Gaming) Restore default joystick saturation for MAME.
  • (Gaming) Return different errors codes when exiting so client has visibility.
  • (Gaming) Wait longer for game transcoder to start.
Plex Media Server 1.21.3.4046 is now available to everyone.
Plex Media Server 1.21.4.4054 is now available to Plex Pass users in the Beta update channel.
NEW:
  • (Web) Updated to 4.51.3
FIXES:
  • (DVR) Newly recorded show Advanced->Seasons setting would not match the Library’s Seasons setting ( plexinc/plex-issues#226 )
  • (DVR) Plex Tuner Service would sometimes shut down while Plex Media Server was still running (#12223).
  • (Gaming) [Windows] Add firewall exception for game transcoder.
  • (Gaming) [Windows] Fix games not being copied over to app support.
  • (Gaming) [Windows] Fix hang stopping game.
  • (Library) Allow deletion of play history again.
  • (Scanner) Respect ‘disc’ suffix for stacked media using the Plex Movie agent (#12315)
  • The server could exit unexpectedly if media was deleted while clients made certain API calls (#12307)
