Hi I am using Plex on a Raspberry Pi.
The current installed version is: Version 1.9.4.4325
So far by default all Movie/TV Libs used the “Plex Movie”-Agent without
no problems, metadata was downloaded correctly.
Suddenly it is not working anymore. Not sure wether it was after the last
update or if there is a different issue.
Things tried:
- Changed Agent to “IMDB” -> still works fine for 90 % of the movies
- Tried to match manually with search function -> does not work
- Restart server/pi -> no improvement
Any suggestions?
