Plex no longer matching movies
Server Version#: 1.22.3.4523
Player Version#: 4.54.5
Originally about 2 months, unable to match a movie unless using the IMDB movie ID. After upgrading the matching, the match doesn’t appear to even check externally. It’s an instant fail.
I have 2 QNAP boxes and they are both running the same version and neither will match movies now.
I haven’t been able to check TV shows yet, but I’m betting this will be the same issue there as well,
In summary, prior to 2 months ago, matching was working automattically, with minor need to “fix match”, then for some reason no movie would match (firmware on the QNAP has been updated a few times). Then I found an article suggesting to match using the IMDB ID, which worked until I updated the matching as recommended by Plex.
Please assist
Same issue here… don’t know why… either qts update or pms…
should get the 4.3.x thing online (now in the cellar) to check…
