Plex not chosing HD channel fo record
I have a schedule recording set up for Formula 1 on UK channel 4. This channel broadcasts on 04 for standard definition and 104 for HD.
I can tune the HD channel just fine, and other recordings default to 104, even if the recording was ‘set up’ by choosing the program on 04 through the guide. This doesn’t work with Formula 1 though, selecting the next race on channel 104 (Channel4HD) the DVR schedule shows that it is going to record on channel 04 in SD. If I alter the recording to ‘HD Only’, it disappears from the schedule altogether!
Any ideas? I’ve tried removing the DVR setup and re-adding, rescanning channels…
Server Version#: 4.78.3
Tuner Make/Model: HD HomeRun Connect HDHR4-2DT
Guide/Lineup name: Freeview
Using XMLTV?:
Channel number/Name: 04 / 104
@fleming164 If you set it to prefer HD and also set it to record on 104 it will record the HD even though it says SD. It’s been like this for a long time.
limit
