Recording oddness when selecting hd channel
When I select to record a Freeview HD channel, it shows recording on the SD channel and not on the HD channel or sometimes it will show both being recorded, even though only one channel selected.
ie I could be watching Channel 4 HD and choose to record the program, which shows when press down to see info section, but if exit the channel and go to the guide the Channel 4 SD is logged as being recorded.
any ideas why this happens, is it a setting within plex that causes this, is the actual channel being recorded the hd or sd version
