I’ll quote it below, but basically I had to change my agent to include The Movie Database, and have it as a higher priority than Freebase.
@ChuckPa said:
I’m going to move this to the Linux forum because it will help afford maximum visibility.
As to your problem of not grabbing all the data, this it telling me there is an issue with how your agents are setup or there is a problem with special characters (non UTF-8) which is a known issue.
The best diagnostic steps are:
Check the actual file names for non-UTF 8 characters.
Make sure the names are correctly named (this is pretty much given since you’re getting something )
Look at how your agents are prioritized.
I’ve included my agent stacking for you to use as comparison.
If you find you need to make a change, then do so.
After that, you’ll need to do the ‘Plex Dance’ for each one which gives you trouble (you can do individually or all at once)
Move media out of where Plex is looking for it
Update the Library (let it finish)
Empty Trash
Clean Bundles (let it finish)
Move files back in and watch as they are picked up
Update the Library
If you’re still not getting full data, we’ll need to see the PMS Plug-ins logs to see what is really going on with it.
Below are mine. (Yes, they show the how-to as well.. sorry)
