Plex not finding tv show
For some reason Plex refuses to show Star Trek Picard. I have used Filebot to correctly name everything and completed the plex dance with no luck. Any ideas? (Kinda new to this).
Named as \Media\TV Shows\Star Trek Picard\Season 01\Star Trek Picard - S01E01 - Remembrance
Is the show not added at all?
What file type are those videos?
No, it doesn’t show at all in Plex.
I have done this and Plex has R/W permission for the whole media folder. It’s in the same ‘TV Shows’ folder that all the other shows are in and it has picked all of the other shows up with no issues
Yeah I did a reset of the permissions as you suggested and this has no effect. I have attached the screenshots you requested.
Do those files have embedded metadata/titles that might be throwing Plex off?
Hmm, I’m not sure. How would I check that?
I have done both of your suggestions and still having no luck!
ill try removing voyager and doing picard first as suggested and let you know how I go tomorrow as it’s getting late here. Thanks!
Do this and don’t worry about it:
Commit this to memory…lol:
Please be careful placing the - if you use that name form.
[chuck@lizum Star Trek- Picard.57]$ cd Season\ 01/
[chuck@lizum Season 01.58]$ ll
total 24694232
drwxr-xr-x 2 chuck chuck       4096 Mar 26 02:46 ./
drwxr-xr-x 3 chuck chuck       4096 Jan 23  2020 ../
-rw-r--r-- 1 chuck chuck 3108017080 Mar 12 02:34 Star Trek- Picard.S01E01.Remembrance.mkv
-rw-r--r-- 1 chuck chuck 3054811831 Mar 12 03:20 Star Trek- Picard.S01E02.Maps and Legends.mkv
-rw-r--r-- 1 chuck chuck 2906237168 Mar 12 01:43 Star Trek- Picard.S01E03.The End is the Beginning.mkv
-rw-r--r-- 1 chuck chuck 3170488823 Mar 12 01:55 Star Trek- Picard.S01E04.Absolute Candor.mkv
-rw-r--r-- 1 chuck chuck 1551966647 Feb 20 03:07 Star Trek- Picard.S01E05.Stardust City Rag.mkv
-rw-r--r-- 1 chuck chuck 1867194314 Feb 27 02:39 Star Trek- Picard.S01E06.The Impossible Box.mkv
-rw-r--r-- 1 chuck chuck 4198092991 Mar 12 02:10 Star Trek- Picard.S01E07.Nepenthe.mkv
-rw-r--r-- 1 chuck chuck 1911747518 Mar 12 02:59 Star Trek- Picard.S01E08.Broken Pieces.mkv
-rw-r--r-- 1 chuck chuck 1549542673 Mar 19 02:33 Star Trek- Picard.S01E09.Et in Arcadia EGO (1).mkv
-rw-r--r-- 1 chuck chuck 1968715386 Mar 26 02:46 Star Trek- Picard.S01E10.Et in Arcadia Ego (2).mkv
[chuck@lizum Season 01.59]$
or (Better choice)
chuck@lizum Season 01.60]$ cd /vie/tv/Star\ Trek\ Picard/
[chuck@lizum Star Trek Picard.61]$ cd Season\ 01/
[chuck@lizum Season 01.62]$ ls -la
total 24694232
drwxrwxr-x 2 chuck chuck       4096 Aug 13 10:23 ./
drwxrwxr-x 3 chuck chuck       4096 Aug 13 10:20 ../
-rw-r--r-- 1 chuck chuck 3108017080 Mar 12 02:34 Star Trek Picard.S01E01.Remembrance.mkv
-rw-r--r-- 1 chuck chuck 3054811831 Mar 12 03:20 Star Trek Picard.S01E02.Maps and Legends.mkv
-rw-r--r-- 1 chuck chuck 2906237168 Mar 12 01:43 Star Trek Picard.S01E03.The End is the Beginning.mkv
-rw-r--r-- 1 chuck chuck 3170488823 Mar 12 01:55 Star Trek Picard.S01E04.Absolute Candor.mkv
-rw-r--r-- 1 chuck chuck 1551966647 Feb 20 03:07 Star Trek Picard.S01E05.Stardust City Rag.mkv
-rw-r--r-- 1 chuck chuck 1867194314 Feb 27 02:39 Star Trek Picard.S01E06.The Impossible Box.mkv
-rw-r--r-- 1 chuck chuck 4198092991 Mar 12 02:10 Star Trek Picard.S01E07.Nepenthe.mkv
-rw-r--r-- 1 chuck chuck 1911747518 Mar 12 02:59 Star Trek Picard.S01E08.Broken Pieces.mkv
-rw-r--r-- 1 chuck chuck 1549542673 Mar 19 02:33 Star Trek Picard.S01E09.Et in Arcadia Ego (1).mkv
-rw-r--r-- 1 chuck chuck 1968715386 Mar 26 02:46 Star Trek Picard.S01E10.Et in Arcadia Ego (2).mkv
[chuck@lizum Season 01.63]$
Thank you that worked! Strange how it thinks it’s voyager even when it is named correctly.
Here are the steps that worked for me.
After moving the media into the Voyager and Pacard folders on my NAS the Plex did put the new Picard season into Voyager.
On the Voyager Series I click the three dots and use the “Split Apart” command. That splits out the Picard as a second Voyager series and a quick rename and scan did the trick.
