I have factory reset my nvidia shield as I have been having issues with my plex server. All has gone well (server is back) but trying to re-map my HDD and it is only showing SD card as an option. Any ideas on how to map this? HDD is showing on my windows laptop and I can play the files so not an issue with the HDD.
How did you register the storage with your Shield?
https://support.plex.tv/articles/220391808-media-storage-options-for-nvidia-shield/
Thanks for your question. When I connect my WB to my shield it says ‘Tap to set up’
If I select ‘Set up as device storage’ it will want to format and I would loose all my data.
So I haven’t actually set it up on my shield. I didn’t think I would need to. The issue I’m having is on my laptop and getting it to pick up the HDD when it is connected to my laptop and I am trying to map it via internet explorer:
(https://app.plex.tv/desktop/#!/settings/server/6b74eee5e02ef20708e34eba82d7b4a6fe707467/manage/libraries)
Yeah I’m a moron, it wasn’t attached to the shield when I was trying to point it to it. It was attached to my laptop - it is now working! Thank you!
