Plex not recognizing certain movie files
Server Version#: 1.22.3.4392
I have an issue with Plex not recognizing a few of my movies.
A movie like
“\Media\Movies, New\American Pickle, An (2020)\American Pickle, An (2020).mkv”
works just fine, but
“Media\Movies, New\Black Bear (2020)\Black Bear (2020).mkv”
doesn’t show up.
The file works fine when played from my PC bypassing Plex, but Plex doesn’t even find it.
If I browse my Plex Movie library by folder, it shows the folder but gives the message “There are no items in this folder”.
Opening the file in MediaInfo I get the following, but I have no idea if there is any clue here as to why Plex doesn’t recognize the file:
General
Unique ID                   : 24716982768352580736235375723511578375 (0x129851566A6484794483D945B6A87F07)
Complete name               : \\DS3018XS\Media\Movies, New\Black Bear (2020)\Black Bear (2020).mkv
Format                      : Matroska
Format version              : Version 4
File size                   : 7.05 GiB
Duration                    : 1 h 45 min
Overall bit rate            : 9 543 kb/s
Encoded date                : UTC 2020-12-04 08:51:39
Writing application         : mkvmerge v44.0.0 ('Domino') 64-bit
Writing library             : libebml v1.3.10 + libmatroska v1.5.2
Video
Format                      : AVC
Format/Info                 : Advanced Video Codec
Format profile              : High@L4
Format settings             : CABAC / 4 Ref Frames
Format settings, CABAC      : Yes
Format settings, Reference  : 4 frames
Codec ID                    : V_MPEG4/ISO/AVC
Bit rate mode               : Constant
Bit rate                    : 8 901 kb/s
Nominal bit rate            : 10 000 kb/s
Width                       : 1 792 pixels
Height                      : 1 080 pixels
Display aspect ratio        : 5:3
Frame rate mode             : Constant
Frame rate                  : 23.976 (24000/1001) FPS
Color space                 : YUV
Chroma subsampling          : 4:2:0
Bit depth                   : 8 bits
Scan type                   : Progressive
Bits/(Pixel*Frame)          : 0.192
Stream size                 : 6.58 GiB (93%)
Default                     : Yes
Forced                      : No
Color range                 : Limited
Color primaries             : BT.709
Transfer characteristics    : BT.709
Matrix coefficients         : BT.709
Audio
Format                      : E-AC-3
Format/Info                 : Enhanced AC-3
Commercial name             : Dolby Digital Plus
Codec ID                    : A_EAC3
Bit rate                    : 640 kb/s
Channel(s)                  : 6 channels
Channel layout              : L R C LFE Ls Rs
Sampling rate               : 48.0 kHz
Frame rate                  : 31.250 FPS (1536 SPF)
Compression mode            : Lossy
Stream size                 : 484 MiB (7%)
Language                    : English
Service kind                : Complete Main
Default                     : Yes
Forced                      : No
Text
Format                      : UTF-8
Codec ID                    : S_TEXT/UTF8
Codec ID/Info               : UTF-8 Plain Text
Duration                    : 1 h 41 min
Bit rate                    : 68 b/s
Count of elements           : 1656
Stream size                 : 51.2 KiB (0%)
Title                       : English (SDH)
Language                    : English
Default                     : No
Forced                      : No
Mod-Edit: minor formatting to make the post easier to read
Plex does not ignore files based on their content… in theory you can add an empty text file – if named properly and with a supported file extension (e.g. mkv). It won’t play but Plex should add it.
On what version of Synology are you (5/6 or 7)?
Could be an issue with permissions if Plex is simply not seeing individual files.
I take it you did do a manual library scan to verify it’s not just a hiccup with the automatic/scheduled scans?
Thank you so much, both of you.
For some reason the movie files had different permissions than the rest of the folder.
You are awesome!
