May I comment on theses names?
The.White.Lotus.S01E04.720p.AMZN.WEBRip.x264-GalaxyTV.mkv
The syntax is <Show Name>Delimiter<SxxExx>Delimiter<Optional Text>.EXT
What’s the show’s name? “The” ?
If this might have worked in the past – luck.
I’m going to recommend renaming ONE as a test
The White Lotus - S01E04 - [720p AMZN WEBRip x264 GalaxyTV].mkv
I don’t know what you use for a collection tool but I suspect it will allow you to specify naming rules.
I will help you with whatever is needed.
I use FileBot and Sonarr.
I also use the full Plex recommended structure
Series folder: {Series Title}
Season folder: Season {season:00} (2 digit seasons)
Episode: {Series Title} - S{season:00}E{episode:00} - {Episode Title}
Yes, these names with spaces are a pain to type at the command line because you have to quote everything but in a GUI? Even at the command line, Linux has "shell completion. I type part of the name, hit tab, and it fills in the rest for me. That’s a pretty neat trick IMO
If I sound harsh, I don’t mean to.
I am only speaking from experience.
Before I got all my naming in order, I had the SAME PROBLEMS . Drove me NUTS!
Since I automated the naming, per the rules, I don’t think twice and PMS NEVER MISSES
