Server Version#:
I got AI to summarise my issues ![]()
- Plex on unraid is mixing show metadata and failing to scrape correctly, misidentifying Obi Wan as the Mandalorian and not detecting Andor as an example
- The user has tried uninstalling and reinstalling Plex, trying different versions, different scanners and different config settings without success
- The user has used Filebot to correctly rename the files if necessary / required and has also used tinymediamanager to generate the relevant NFO files
Completely and totally stuck. Could really use some help with this one please!
