Server Version#: 1.24.2.4973
Server Type: Qnap TVS-882 (i5 7500)
Player Version#: 7.23 (1076)
Hello - and thank you for reading this. I’m a bit of an amateur at this so please bear with how I set up my question/situation. I’ve read several similar threads on the Plex forums but they either determine the fix to be something that doesn’t apply to my situation or the thread has died with no apparent solution.
I have a Plex library with almost 1,000 movies that I’ve ripped over the last 15+ years from my own collection of DVDs, Blu-Rays, and UHD discs, probably a 45/45/10 split respectively. For fun (I’m a weirdo perhaps) I’ve decided I’d embark on the tasks of re-ripping and re-encoding my movies to make sure that they are all up to my current standards and to use H.265 - with the idea of saving disk space.
The devices our family use for Plex movie viewing are almost always AppleTVs. We have 4 total, two of the second gen 4K models, a first gen 4K model, and one HD model. In the past I’ve usually ripped my movies using MakeMKV and encode using Handbrake using the “General Super HQ” Surround preset with the appropriate resolution for the original source media. This has generally meant that H.264 was used as the video encoder.
For audio - I only include one track and I always use passthrough for the best audio track on the disc. I don’t care about space savings when it comes to the audio track.
For the re-rips that I’ve done so far, I’ve tried both the “Devices Apple” preset and the “General Super HQ” preset with the appropriate resolution for the original source media. However, on on the Video tab I’ve changed the encoder to H.265 and left the other video settings the same. Most of the time I leave the format option at the default which is MP4, but occasionally I need to change it to MKV to allow TrueHD to be set to passthrough.
The disk space savings have been impressive so far, some times up to 20%. The quality of the video looks every bit as good as the H.264 video except…
The issue: There are very noticeable hiccups, or stutters, in the video playback. If you’re not watching closely you may miss them, and it doesn’t always happen in the same places if you rewind and rewatch a spot. I’ve found that I can most easily observe the skipping or stuttering by watching scrolling credits. It seems to happen easily once every 15 seconds or so.
I’ve checked the CPU usage on my Plex server and it doesn’t seem to be taxed, Plex is generally using <10% of the CPU.
These are the Handbrake settings I’m using
Summary Tab
Dimensions Tab
Filters Tab
Video Tab
Audio Tab
Subtitles Tab
Chapters Tab
Things I’ve checked/tried and observances
-Turning match framerate on/off on the AppleTV settings. Makes no difference
-Turning the enhanced player in Plex settings on the AppleTV on/off. Makes no difference
-Infuse on the AppleTV playing the same file. No stuttering is present
-Plex web client on a Windows PC. No stuttering is present
-H.265 files I’ve obtained from other sources don’t have the stuttering.
Its very frustrating to be able to create H.264 movies that play fine but not H.265 files. I am chomping at the bit to covert my library to H.265.
I would be grateful for tip or ideas I can try.
Thank you
Also, the encode without audio had the same stuttering as well.
