Server Version#: PlexMediaServer-1.24.2.4973-2b1b51db9-x86_64
So I uninstalled the Qnap Plex app, reinstalled it, upgraded to the latest version and now it will not load in my browse with the url I’ve been using for years: http://10.0.10.4:32400/web/index.html#!/ It just never loads
I’ve been running Plex on this server for the past 4 years or so.
If I browse to https://app.plex.tv/desktop/#!/ Plex loads but does not seem to connect to the local version on my Qnap. Left col shows YOUR MEDIA and when I click that the main screen shows “Add your media to Plex” with a button to download the server installation file.
I’ve rebooted and cannot figure out what is wrong. @ChuckPa can you please help?
Bob M.
Here are teh log files. I do see the following errors:
Sep 09, 2021 16:03:25.571 [0x7f80413aed48] ERROR - HttpServer: Error binding acceptor: Address in use
Sep 09, 2021 16:03:25.571 [0x7f80413aed48] ERROR - HttpServer: Error opening acceptor on IPv6, falling back to IPv4: Address in use
Sep 09, 2021 16:03:25.571 [0x7f80413aed48] ERROR - Error: Unable to set up server: listen: Address in use (N5boost10wrapexceptINS_6system12system_errorEEE)download_2021-09-09_16-19-01.zip (191.3 KB)
How is this done? I don’t know how to I log into the server via SSH and rant netstat . Please help! I cant access Plex since updating my Qnap firmware.
Using PUTTY or ssh , open the connection to the QNAP, signing in as admin with the admin password. Do not use “an administrative user” . Such users do not have the necessary privileges at the Linux level.
Is there any other way around this? I am not that technical. I am having issues accessing Plex from outside my network. I didn’t have this issue before. I’ve tried just about everything I can think of from uninstalling/ installing, port forwarding, automatic detection, rebooting my QNAP NAS, Router/ Modem. Thank you for your reply and advise.
I have the same problem, but cannot fix it with the provided solutions. This is what happens:
When I try to connect to Plex, I get the “This site can’t be reached” error.
I connected to my QNAP server with ssh, went to “/etc/init.d/”, and there I ran “sudo ./plex.sh start”.
The “Starting Plex Media Server…” message appeared, and after a few seconds, this message appeared: “./plex.sh: line 195: ./Plex Media Server: is a directory”.
I checked and noticed that the script is trying to run a “Plex Media Server” program that is not there.
I installed the version provided by Plex, but got the same results.
I also installed the version provided by QNAP, also with the same results.
