Plex on shield tv issue
Hi, after I dont know which update, plex player on my shield tv has some problems with playing movies
Could you share the client logs, info on grabbing the client logs is available here: https://support.plex.tv/articles/201573117-android-android-tv-fire-tv-logs/
After new update, plex on shield works very well
Ah, you most likely experienced an issue with AC3 or AAC_LATM which we fixed in the last beta update. Glad to hear it’s sorted!
I am experiencing the same issue with Shield TV. I have the latest update but keep getting the error message when trying to play movies. If I remove the update, the videos will play, but there is an issue with the passthrough and optical audio with the old version.
Any idea how to fix?
