Yes maybe 6 months ago I migrated from Win 10 to Synology
Sorry I need the raw files zipped and attached as zip so as to preserve the CR LF characters - pasting here would not show if there is a hex 0A or hex 10 etc at the end of the line
Thank you
We do have CRLF at end of lines instead of just LF. My theory is that these were added when the system was running on windows
End of Line on windows is Carriage Return / Linefeed (CR LF)
On Linux it is just Line Feed (LF)
My theory is that these cookies were added when the system was running on windows. A recent change to one of the http code modules introduced extra validation and the unexpected Carriage Returns that came from windows started to give the errors
It should be sufficient to delete these HTTPCookies files and they will get recreated
I would be interested if we do still end up with a CR LF at the end of line after doing this
So just delete
Application Support/Plex Media Server/Plug-in Support/Data/com.plexapp.agents.thetvdb/HTTPCookies
and
Application Support/Plex Media Server/Plug-in Support/Data/com.plexapp.system/HTTPCookies
and refresh all metadata for the libraries
If still an issue, would like logs and the zipped HTTPCookies files
Deleted the entire plugin data folder and rebooted. The issue has been resolved for me. I did migrate from windows to Synology months ago.
I am having a similar issue with plex server 1.18.3.2156 on Synology. When I add a movie no metadata is pulled down and no matches appear when I try to manually match by adding imdb number/ year etc.
I tried deleting the folder contents mentioned above also to no avail.
Many thanks in advance for anyone that can help
Logs attached Plex Media Server Logs_2019-12-21_23-29-47.zip (2.4 MB)
you have a few errors in your logs:
/Plexdoesn’t exist./volume1/Plex/tmp_transcodingis created for you by the installation scripts.
Dec 21, 2019 23:22:41.077 [0x7f50e9928740] ERROR - Error creating directory "/Plex/tmp_transcoding": Permission denied
- External Internet connectivity / DNS lookup is not working. Control Panel - Networks (error 6 = DNS lookup failure)
Dec 21, 2019 23:22:47.154 [0x7f50d7447700] ERROR - Error issuing curl_easy_perform(handle): 6
Dec 21, 2019 23:22:47.154 [0x7f50d7447700] WARN - HTTP error requesting GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx (0, No error) (Could not resolve host: plex.tv)
Dec 21, 2019 23:22:47.154 [0x7f50d7447700] ERROR - Error parsing content.
Dec 21, 2019 23:22:47.154 [0x7f50d7447700] ERROR - Error parsing XML: Error parsing file.
Dec 21, 2019 23:22:47.154 [0x7f50d6e6b700] ERROR - Error issuing curl_easy_perform(handle): 6
Once you’ve resolved the external connectivity issues, restart PMS and try again.
Thank you
I received a new router recently and it seems some settings weren’t 100%
It seems to be working now
I also am running plex on a ds918+, moved from a windows server and started having this problem a month or two ago. Deleting everything in the Plex/Library/Application Support/Plex Media Server/Plug-in Support/Data folder fixed this! Thanks for figuring this out!
