Plex on Synology using quick Connect (for Syn.Drive)?
Server Version#:
hello,
i love my plex - and I love my synology
now I would like to enable quick connect (needed for synology drive) but still access plex. Is there any possibility to do so?
Using: plex 7.0, Synology Ds220+
Best regards,
Johannes
You can use QuickConnect if the server is all setup and attached to your account.
The only difficulty arises when you try to use QuickConnect to claim the server.
I’ve written a lot into the installer, which gives you a way to claim the server when normal claiming doesn’t work, but sometimes QuickConnect still prevents things from working right.
