Great news! @sLumpy please say if we can help you with Samsung. Maybe we should write to them together or vote for bugfix?
This should now be fixed in 5.32.1.
No need. Pretty sure theyβd just get upset at us for spamming them for a bug that we have a workaround for.
Thank you for your efforts!
I updated both TV and server, to the newest version, but still no luck!
When I try to change the audio track to German for example, then it just starts spinning, and nothing happens! When I switch back to English then it works as it should.
The German track is AAC Stereo.
The English track is AC3 5.1.
The fun part is that the English track gets transcoded/converted into AAC but when I try to watch something with AAC Stereo or Stereo MP3 then it does not work.
One other thing I noticed is whenever I have a movie with and audio track labeled Unknown instead of the language name, then it also fails to playback.
Maybe these are errors/mistakes on my side. If so, then please tell me what to fix.
Thanks again for your efforts!
Thank you! It works!!!
What about my first question?
- TV App doesnβt show the NAMES of the tracks (it shows only language and stereo mode instead) - itβs not good when you have 3-5 translation tracks in the movie
Should I create a different topic for this?
Also Iβve found a very old topic (since 2017) about a very important and useful feature: setting (or just saving) choice of subtitles and audio tracks for a whole season of a tv show - why hasnβt it been done yet? Who is responsible for new featuresβ backlog?
Do you have transcoding enabled on the server? It needs to direct stream on audio track switch. If thatβs not the issue then Iβll need new logs.
Yes please.
Itβs been discussed internally, and we do want to do it. Canβt say much more than that.
I turned transcode back on and it seems itβs almost fixed.
But strange thing is that after that I have turned that back on, I have movies which go into transcoding, which were direct playing before.
I try to send some logs hopefully it helps you!
So in this scenario I have this option activated(I guess thatβs transcoding turned off):
When I try to play an episode from the series which has only two audio tracks (German, English) and both of them have the same codec, then when I play the English one:
Then I works great, and I get this log:
Feb 25, 2022 10:33:53.578 [8032] Debug β [EventSourceClient/pubsub] Resolving 172.104.132.7 port 443
Feb 25, 2022 10:33:53.578 [8032] Debug β [EventSourceClient/pubsub] Resolved 172.104.132.7 to 172.104.132.7
Feb 25, 2022 10:33:53.680 [8008] Debug β [EventSourceClient/pubsub] Connected in 70 ms.
Feb 25, 2022 10:33:53.681 [8032] Debug β [EventSourceClient/pubsub] Wrote data, reading reply.
Feb 25, 2022 10:33:53.816 [8032] Debug β [EventSourceClient/pubsub] Read HTTP reply header.
Feb 25, 2022 10:33:53.816 [8032] Debug β [EventSourceClient/pubsub] MyPlex: We appear to have regained Internet connectivity.
Feb 25, 2022 10:33:53.845 [8032] Debug β [EventSourceClient/pubsub] PublicAddressManager: Obtaining public address and mapping port.
Feb 25, 2022 10:33:53.846 [12064] Debug β [EventSourceClient/pubsub] PublicAddressManager: Obtaining public IP.
Feb 25, 2022 10:33:53.846 [8032] Debug β [EventSourceClient/pubsub] MyPlex: async reachability check - current mapped state: 'Mapped'.
Feb 25, 2022 10:33:53.846 [8032] Debug β [EventSourceClient/pubsub] MyPlex: Requesting reachability check.
Feb 25, 2022 10:33:53.846 [12064] Debug β [EventSourceClient/pubsub] HTTP requesting GET http://plex.tv/pms/:/ip
Feb 25, 2022 10:33:53.846 [8032] Debug β [EventSourceClient/pubsub] HTTP requesting PUT https://plex.tv/api/servers/7c171af2ebf3f9cc9394acd95cefa3ec3b71027b/connectivity?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx&asyncIdentifier=9a753a93-bf7e-40e7-b45f-1dcdd5478520
Feb 25, 2022 10:33:54.115 [14636] Debug β [HttpClient] HTTP/2.0 (0.3s) 200 response from PUT https://plex.tv/api/servers/7c171af2ebf3f9cc9394acd95cefa3ec3b71027b/connectivity?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx&asyncIdentifier=9a753a93-bf7e-40e7-b45f-1dcdd5478520
Feb 25, 2022 10:33:54.116 [8032] Debug β [EventSourceClient/pubsub] Successfully connected to 172.104.132.7.
Feb 25, 2022 10:33:54.241 [14636] Debug β [HttpClient] HTTP/2.0 (0.4s) 200 response from GET http://plex.tv/pms/:/ip
Feb 25, 2022 10:33:54.241 [12064] Debug β [EventSourceClient/pubsub] PublicAddressManager: Got public IP from http://plex.tv: 45.153.149.187
Feb 25, 2022 10:33:54.297 [2528] Debug β Request: [192.168.1.44:49799 (Subnet)] POST /playQueues?own=1&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto&excludeFields=file%2Ctagline&uri=server%3A%2F%2F7c171af2ebf3f9cc9394acd95cefa3ec3b71027b%2Fcom.plexapp.plugins.library%2Flibrary%2Fmetadata%2F445&type=video&continuous=1&includeRelated=0&shuffle=0&repeat=0&key=%2Flibrary%2Fmetadata%2F452 (10 live) GZIP Signed-in Token (qw2my)
Feb 25, 2022 10:33:54.298 [2528] Debug β PlayQueue: Converted 'server://7c171af2ebf3f9cc9394acd95cefa3ec3b71027b/com.plexapp.plugins.library/library/metadata/445' to 'library://x/item/%2Flibrary%2Fmetadata%2F445'
Feb 25, 2022 10:33:54.299 [2528] Debug β PlayQueue: 0 generated IDs compressed down to a 20 byte blob.
Feb 25, 2022 10:33:54.308 [2528] Debug β PlayQueue: Start index: 0 End index: 45 Count: 46
Feb 25, 2022 10:33:54.308 [2528] Debug β PlayQueue: 46 generated IDs compressed down to a 101 byte blob.
Feb 25, 2022 10:33:54.310 [2528] Debug β PlayQueue: Added 46 items in 0.0 sec.
Feb 25, 2022 10:33:54.376 [2528] Debug β It took 62.500000 ms to retrieve 26 items.
Feb 25, 2022 10:33:54.412 [8008] Debug β Completed: [192.168.1.44:49799] 200 POST /playQueues?own=1&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto&excludeFields=file%2Ctagline&uri=server%3A%2F%2F7c171af2ebf3f9cc9394acd95cefa3ec3b71027b%2Fcom.plexapp.plugins.library%2Flibrary%2Fmetadata%2F445&type=video&continuous=1&includeRelated=0&shuffle=0&repeat=0&key=%2Flibrary%2Fmetadata%2F452 (11 live) GZIP 115ms 9474 bytes (pipelined: 1)
Feb 25, 2022 10:33:54.443 [2528] Debug β Request: [192.168.1.44:49799 (Subnet)] GET /library/metadata/452?checkFiles=1&includeChapters=1&includeMarkers=1 (11 live) GZIP Signed-in Token (qw2my)
Feb 25, 2022 10:33:54.449 [15448] Debug β Request: [54.170.120.91:44232 (WAN)] GET /identity (11 live) TLS Signed-in
Feb 25, 2022 10:33:54.451 [8008] Debug β Completed: [54.170.120.91:44232] 200 GET /identity (11 live) TLS 2ms 398 bytes (pipelined: 1)
Feb 25, 2022 10:33:54.473 [2528] Debug β Audio Stream: 1848, Subtitle Stream: 0
Feb 25, 2022 10:33:54.479 [8008] Debug β Completed: [192.168.1.44:49799] 200 GET /library/metadata/452?checkFiles=1&includeChapters=1&includeMarkers=1 (11 live) GZIP 35ms 2729 bytes (pipelined: 2)
Feb 25, 2022 10:33:54.507 [2528] Debug β Request: [192.168.1.44:49799 (Subnet)] GET /video/:/transcode/universal/decision?directPlay=1&directStream=1&directStreamAudio=1&protocol=dash&fastSeek=1&path=%2Flibrary%2Fmetadata%2F452&session=4n8yasu7kr4ts51j524dqfli&mediaIndex=0&partIndex=0&mediaBufferSize=50000&hasMDE=1&subtitleSize=100&videoQuality=100&videoResolution=4096x2160&audioBoost=700&location=lan (11 live) GZIP Signed-in Token (qw2my)
Feb 25, 2022 10:33:54.508 [2528] Debug β [Transcode] Found session GUID of 4n8yasu7kr4ts51j524dqfli in session start.
Feb 25, 2022 10:33:54.511 [2528] Debug β [Transcode] TranscodeUniversalRequest: using augmented profile Generic
Feb 25, 2022 10:33:54.511 [2528] Debug β [Transcode] Downloading document http://127.0.0.1:32400/library/metadata/452?includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=wjgbq5q4t1ekha3i6v34jsdt
Feb 25, 2022 10:33:54.537 [2528] Debug β [Transcode] Audio Stream: 1848, Subtitle Stream: 0
Feb 25, 2022 10:33:54.545 [2528] Debug β [Transcode] Streaming Resource: Reached Decision id=452 codes=(MDE=1000,Direct play OK.) media=(id=787 part=(id=787 decision=direct play protocol=dash streams=(Video=(id=1847 decision= width=720 height=576) Audio=(id=1848 decision= channels=0 rate=0))))
Feb 25, 2022 10:33:54.547 [8032] Debug β Completed: [192.168.1.44:49799] 200 GET /video/:/transcode/universal/decision?directPlay=1&directStream=1&directStreamAudio=1&protocol=dash&fastSeek=1&path=%2Flibrary%2Fmetadata%2F452&session=4n8yasu7kr4ts51j524dqfli&mediaIndex=0&partIndex=0&mediaBufferSize=50000&hasMDE=1&subtitleSize=100&videoQuality=100&videoResolution=4096x2160&audioBoost=700&location=lan (11 live) GZIP 39ms 2294 bytes (pipelined: 3)
Feb 25, 2022 10:33:54.745 [2528] Debug β Request: [192.168.1.44:49800 (Subnet)] GET /library/parts/787/1642510907/file.mkv?Accept=application%2Fjson&Accept-Language=en (12 live) Signed-in Token (qw2my) (range: bytes=0-)
Feb 25, 2022 10:33:54.748 [15448] Debug β Request: [192.168.1.44:49799 (Subnet)] GET /:/timeline?key=%2Flibrary%2Fmetadata%2F452&ratingKey=452&state=buffering&time=238419&duration=2527400&playbackTime=0&playQueueItemID=1902&context=home%3Ahub.continueWatching&row=0&col=3 (12 live) GZIP Signed-in Token (qw2my)
Feb 25, 2022 10:33:54.750 [15448] Debug β Client [wjgbq5q4t1ekha3i6v34jsdt] reporting timeline state buffering, progress of 238419/2527400ms for guid=, playbackTime=0ms ratingKey=452 url=, key=/library/metadata/452, containerKey=, metadataId=452, source=
Feb 25, 2022 10:33:54.753 [2528] Debug β Content-Length of D:\The Mentalist RIP\Staffel 1\The Mentalist S01E06.mkv is 1710367794 (of total: 1710367794).
Feb 25, 2022 10:33:54.754 [15448] Debug β Play progress on 452 'Tisch 43' - got played 238419 ms by account 1!
Feb 25, 2022 10:33:57.124 [2528] Debug β WebSocket: Performing handshake from origin https://app.plex.tv
Feb 25, 2022 10:33:57.124 [2528] Debug β Beginning read from WebSocket
Feb 25, 2022 10:33:57.138 [2528] Debug β Request: [192.168.1.86:57833 (Subnet)] GET /activities (15 live) TLS GZIP Signed-in Token (qw2my)
Feb 25, 2022 10:33:57.139 [8032] Debug β Completed: [192.168.1.86:57833] 200 GET /activities (15 live) TLS GZIP 1ms 475 bytes (pipelined: 3)
Feb 25, 2022 10:33:59.515 [8032] Debug β Completed: [127.0.0.1:51386] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (15 live) GZIP 20008ms 5 bytes (pipelined: 129)
Feb 25, 2022 10:33:59.541 [2528] Debug β Request: [127.0.0.1:51386 (Loopback)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (15 live) GZIP Signed-in Token (qw2my)
Feb 25, 2022 10:33:59.541 [2528] Debug β Content-Length is -1 (of total: -1).
Feb 25, 2022 10:34:00.875 [12064] Debug β [EventSourceClient/pubsub] NAT: UPnP, found device <http://192.168.1.52:80/description.xml> with private address <192.168.1.72>
Feb 25, 2022 10:34:00.876 [12064] Debug β [EventSourceClient/pubsub] NAT: UPnP, not an IGD: <http://192.168.1.52:80/description.xml>.
Feb 25, 2022 10:34:00.889 [12064] Debug β [EventSourceClient/pubsub] NAT: UPnP, found device <http://192.168.1.52:80/description.xml> with private address <192.168.1.72>
Feb 25, 2022 10:34:00.889 [12064] Debug β [EventSourceClient/pubsub] NAT: UPnP, not an IGD: <http://192.168.1.52:80/description.xml>.
Feb 25, 2022 10:34:00.902 [12064] Debug β [EventSourceClient/pubsub] NAT: UPnP, found device <http://192.168.1.52:80/description.xml> with private address <192.168.1.72>
Feb 25, 2022 10:34:00.902 [12064] Debug β [EventSourceClient/pubsub] NAT: UPnP, not an IGD: <http://192.168.1.52:80/description.xml>.
Feb 25, 2022 10:34:00.906 [12064] Debug β [EventSourceClient/pubsub] NAT: UPnP, found device <http://192.168.1.1:49152/IGDdevicedesc1.xml> with private address <192.168.1.72>
Feb 25, 2022 10:34:00.915 [12064] Debug β [EventSourceClient/pubsub] NAT: UPnP, usable device <http://192.168.1.1:49152/IGDdevicedesc1.xml> with private address <192.168.1.72>.
Feb 25, 2022 10:34:00.920 [12064] Debug β [EventSourceClient/pubsub] NAT: UPnP, public address is 45.153.149.187
Feb 25, 2022 10:34:00.921 [12064] Debug β [EventSourceClient/pubsub] HTTP requesting GET https://45-153-149-187.905230b2a1e649b3a12a347f12a06060.plex.direct:32401/identity
Feb 25, 2022 10:34:00.965 [6608] Debug β Request: [192.168.1.1:53058 (Subnet)] GET /identity (16 live) TLS GZIP Signed-in
Feb 25, 2022 10:34:01.013 [14636] Debug β [HttpClient] HTTP/1.1 (0.1s) 200 response from GET https://45-153-149-187.905230b2a1e649b3a12a347f12a06060.plex.direct:32401/identity
Feb 25, 2022 10:34:01.014 [8032] Debug β Completed: [192.168.1.1:53058] 200 GET /identity (16 live) TLS GZIP 49ms 479 bytes (pipelined: 1)
Feb 25, 2022 10:34:01.014 [12064] Debug β [EventSourceClient/pubsub] MyPlex: mapping state set to 'Mapped - Not Published'.
Feb 25, 2022 10:34:01.045 [12064] Debug β [EventSourceClient/pubsub] MyPlex: Updating device connections (from timer: 0)
Feb 25, 2022 10:34:01.046 [12064] Debug β [EventSourceClient/pubsub] HTTP requesting PUT https://plex.tv/devices/7c171af2ebf3f9cc9394acd95cefa3ec3b71027b?Connection[][uri]=http://192.168.1.72:32400&httpsEnabled=1&httpsRequired=0&dnsRebindingProtection=0&natLoopbackSupported=1&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Feb 25, 2022 10:34:01.136 [14636] Debug β [HttpClient] HTTP/2.0 (0.1s) 200 response from PUT https://plex.tv/devices/7c171af2ebf3f9cc9394acd95cefa3ec3b71027b?Connection[][uri]=http://192.168.1.72:32400&httpsEnabled=1&httpsRequired=0&dnsRebindingProtection=0&natLoopbackSupported=1&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx (reused)
Feb 25, 2022 10:34:05.407 [8032] Debug β Completed: [192.168.1.86:57654] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (16 live) TLS GZIP 20002ms 5 bytes (pipelined: 98)
Feb 25, 2022 10:34:05.436 [6608] Debug β Request: [192.168.1.86:57654 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (16 live) TLS GZIP Signed-in Token (qw2my)
Feb 25, 2022 10:34:05.437 [6608] Debug β Content-Length is -1 (of total: -1).
Feb 25, 2022 10:34:06.154 [2528] Debug β Request: [192.168.1.44:49804 (Subnet)] GET /:/timeline?key=%2Flibrary%2Fmetadata%2F452&ratingKey=452&state=playing&time=249335&duration=2527400&playbackTime=10621&playQueueItemID=1902&context=home%3Ahub.continueWatching&row=0&col=3 (16 live) GZIP Signed-in Token (qw2my)
Feb 25, 2022 10:34:06.156 [2528] Debug β Client [wjgbq5q4t1ekha3i6v34jsdt] reporting timeline state playing, progress of 249335/2527400ms for guid=, playbackTime=10621ms ratingKey=452 url=, key=/library/metadata/452, containerKey=, metadataId=452, source=
Feb 25, 2022 10:34:06.159 [2528] Debug β Play progress on 452 'Tisch 43' - got played 249335 ms by account 1!
Feb 25, 2022 10:34:06.164 [2528] Debug β [Now] User is qw2my (ID: 1)
Feb 25, 2022 10:34:06.165 [2528] Debug β [Now] Device is Tizen (TV 2021).
Feb 25, 2022 10:34:06.169 [2528] Error β Unable to find client profile for device; platform=Tizen, platformVersion=6, device=21_NIKEL_UHD, model=QE50Q60AAUXXH
Feb 25, 2022 10:34:06.169 [2528] Debug β [Now] Updated play state for /library/metadata/452.
Feb 25, 2022 10:34:06.170 [2528] Debug β Statistics: (wjgbq5q4t1ekha3i6v34jsdt) Reporting active playback in state 0 of type 4 (scrobble: 0) for account 1
Feb 25, 2022 10:34:06.175 [8008] Debug β Completed: [192.168.1.44:49804] 200 GET /:/timeline?key=%2Flibrary%2Fmetadata%2F452&ratingKey=452&state=playing&time=249335&duration=2527400&playbackTime=10621&playQueueItemID=1902&context=home%3Ahub.continueWatching&row=0&col=3 (16 live) GZIP 21ms 496 bytes (pipelined: 2)
Feb 25, 2022 10:34:06.734 [6608] Debug β Request: [192.168.1.44:49804 (Subnet)] GET /:/timeline?key=%2Flibrary%2Fmetadata%2F452&ratingKey=452&state=paused&time=249835&duration=2527400&playbackTime=11201&playQueueItemID=1902&context=home%3Ahub.continueWatching&row=0&col=3 (16 live) GZIP Signed-in Token (qw2my)
Feb 25, 2022 10:34:06.736 [6608] Debug β Client [wjgbq5q4t1ekha3i6v34jsdt] reporting timeline state paused, progress of 249835/2527400ms for guid=, playbackTime=11201ms ratingKey=452 url=, key=/library/metadata/452, containerKey=, metadataId=452, source=
Feb 25, 2022 10:34:06.739 [6608] Debug β Play progress on 452 'Tisch 43' - got played 249835 ms by account 1!
Feb 25, 2022 10:34:06.756 [6608] Debug β [Now] User is qw2my (ID: 1)
Feb 25, 2022 10:34:06.757 [6608] Debug β [Now] Device is Tizen (TV 2021).
Feb 25, 2022 10:34:06.761 [6608] Error β Unable to find client profile for device; platform=Tizen, platformVersion=6, device=21_NIKEL_UHD, model=QE50Q60AAUXXH
Feb 25, 2022 10:34:06.761 [6608] Debug β [Now] Updated play state for /library/metadata/452.
Feb 25, 2022 10:34:06.762 [6608] Debug β Statistics: (wjgbq5q4t1ekha3i6v34jsdt) Reporting active playback in state 1 of type 4 (scrobble: 0) for account 1
Feb 25, 2022 10:34:06.767 [8008] Debug β Completed: [192.168.1.44:49804] 200 GET /:/timeline?key=%2Flibrary%2Fmetadata%2F452&ratingKey=452&state=paused&time=249835&duration=2527400&playbackTime=11201&playQueueItemID=1902&context=home%3Ahub.continueWatching&row=0&col=3 (16 live) GZIP 33ms 496 bytes (pipelined: 3)
Feb 25, 2022 10:34:08.547 [8032] Debug β Completed: [192.168.1.44:49696] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cplayqueues&timeout=1 (16 live) GZIP 20002ms 5 bytes (pipelined: 59)
Feb 25, 2022 10:34:08.559 [2528] Debug β Request: [192.168.1.44:49696 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cplayqueues&timeout=1 (16 live) GZIP Signed-in Token (qw2my)
Feb 25, 2022 10:34:08.559 [2528] Debug β Content-Length is -1 (of total: -1).
Feb 25, 2022 10:34:19.546 [8032] Debug β Completed: [127.0.0.1:51386] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (14 live) GZIP 20005ms 5 bytes (pipelined: 130)
Feb 25, 2022 10:34:19.573 [2528] Debug β Request: [127.0.0.1:51386 (Loopback)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (14 live) GZIP Signed-in Token (qw2my)
Feb 25, 2022 10:34:19.573 [2528] Debug β Content-Length is -1 (of total: -1).
Feb 25, 2022 10:34:21.735 [2528] Debug β Request: [192.168.1.44:49804 (Subnet)] GET /:/timeline?key=%2Flibrary%2Fmetadata%2F452&ratingKey=452&state=paused&time=249835&duration=2527400&playbackTime=11201&playQueueItemID=1902&context=home%3Ahub.continueWatching&row=0&col=3 (13 live) GZIP Signed-in Token (qw2my)
Feb 25, 2022 10:34:21.737 [2528] Debug β Client [wjgbq5q4t1ekha3i6v34jsdt] reporting timeline state paused, progress of 249835/2527400ms for guid=, playbackTime=11201ms ratingKey=452 url=, key=/library/metadata/452, containerKey=, metadataId=452, source=
Feb 25, 2022 10:34:21.740 [2528] Debug β Play progress on 452 'Tisch 43' - got played 249835 ms by account 1!
Feb 25, 2022 10:34:21.745 [2528] Debug β [Now] User is qw2my (ID: 1)
Feb 25, 2022 10:34:21.746 [2528] Debug β [Now] Device is Tizen (TV 2021).
Feb 25, 2022 10:34:21.750 [2528] Error β Unable to find client profile for device; platform=Tizen, platformVersion=6, device=21_NIKEL_UHD, model=QE50Q60AAUXXH
Feb 25, 2022 10:34:21.750 [2528] Debug β [Now] Updated play state for /library/metadata/452.
Feb 25, 2022 10:34:21.751 [2528] Debug β Statistics: (wjgbq5q4t1ekha3i6v34jsdt) Reporting active playback in state 1 of type 4 (scrobble: 0) for account 1
Feb 25, 2022 10:34:21.756 [8032] Debug β Completed: [192.168.1.44:49804] 200 GET /:/timeline?key=%2Flibrary%2Fmetadata%2F452&ratingKey=452&state=paused&time=249835&duration=2527400&playbackTime=11201&playQueueItemID=1902&context=home%3Ahub.continueWatching&row=0&col=3 (13 live) GZIP 20ms 496 bytes (pipelined: 4)
Feb 25, 2022 10:34:25.442 [8032] Debug β Completed: [192.168.1.86:57654] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (11 live) TLS GZIP 20006ms 5 bytes (pipelined: 99)
Feb 25, 2022 10:34:25.478 [2528] Debug β Request: [192.168.1.86:57654 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (11 live) TLS GZIP Signed-in Token (qw2my)
Feb 25, 2022 10:34:25.478 [2528] Debug β Content-Length is -1 (of total: -1).
Feb 25, 2022 10:34:28.572 [8008] Debug β Completed: [192.168.1.44:49696] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cplayqueues&timeout=1 (11 live) GZIP 20012ms 5 bytes (pipelined: 60)
Feb 25, 2022 10:34:28.583 [2528] Debug β Request: [192.168.1.44:49696 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cplayqueues&timeout=1 (11 live) GZIP Signed-in Token (qw2my)
Feb 25, 2022 10:34:28.583 [2528] Debug β Content-Length is -1 (of total: -1).
Feb 25, 2022 10:34:36.736 [2528] Debug β Request: [192.168.1.44:49804 (Subnet)] GET /:/timeline?key=%2Flibrary%2Fmetadata%2F452&ratingKey=452&state=paused&time=249835&duration=2527400&playbackTime=11201&playQueueItemID=1902&context=home%3Ahub.continueWatching&row=0&col=3 (11 live) GZIP Signed-in Token (qw2my)
Feb 25, 2022 10:34:36.738 [2528] Debug β Client [wjgbq5q4t1ekha3i6v34jsdt] reporting timeline state paused, progress of 249835/2527400ms for guid=, playbackTime=11201ms ratingKey=452 url=, key=/library/metadata/452, containerKey=, metadataId=452, source=
Feb 25, 2022 10:34:36.742 [2528] Debug β Play progress on 452 'Tisch 43' - got played 249835 ms by account 1!
Feb 25, 2022 10:34:36.747 [2528] Debug β [Now] User is qw2my (ID: 1)
Feb 25, 2022 10:34:36.747 [2528] Debug β [Now] Device is Tizen (TV 2021).
Feb 25, 2022 10:34:36.752 [2528] Error β Unable to find client profile for device; platform=Tizen, platformVersion=6, device=21_NIKEL_UHD, model=QE50Q60AAUXXH
Feb 25, 2022 10:34:36.752 [2528] Debug β [Now] Updated play state for /library/metadata/452.
Feb 25, 2022 10:34:36.752 [2528] Debug β Statistics: (wjgbq5q4t1ekha3i6v34jsdt) Reporting active playback in state 1 of type 4 (scrobble: 0) for account 1
Feb 25, 2022 10:34:36.757 [8032] Debug β Completed: [192.168.1.44:49804] 200 GET /:/timeline?key=%2Flibrary%2Fmetadata%2F452&ratingKey=452&state=paused&time=249835&duration=2527400&playbackTime=11201&playQueueItemID=1902&context=home%3Ahub.continueWatching&row=0&col=3 (11 live) GZIP 21ms 496 bytes (pipelined: 5)
When I switch it outside (before I start to play) to German, then this happens in the console:
Feb 25, 2022 10:39:45.718 [3780] Debug β Request: [192.168.1.44:49818 (Subnet)] POST /playQueues?own=1&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto&excludeFields=file%2Ctagline&uri=server%3A%2F%2F7c171af2ebf3f9cc9394acd95cefa3ec3b71027b%2Fcom.plexapp.plugins.library%2Flibrary%2Fmetadata%2F445&type=video&continuous=1&includeRelated=0&shuffle=0&repeat=0&key=%2Flibrary%2Fmetadata%2F452 (17 live) GZIP Signed-in Token (qw2my)
Feb 25, 2022 10:39:45.718 [3780] Debug β PlayQueue: Converted 'server://7c171af2ebf3f9cc9394acd95cefa3ec3b71027b/com.plexapp.plugins.library/library/metadata/445' to 'library://x/item/%2Flibrary%2Fmetadata%2F445'
Feb 25, 2022 10:39:45.719 [3780] Debug β PlayQueue: 0 generated IDs compressed down to a 20 byte blob.
Feb 25, 2022 10:39:45.721 [3780] Debug β PlayQueue: Start index: 0 End index: 45 Count: 46
Feb 25, 2022 10:39:45.721 [3780] Debug β PlayQueue: 46 generated IDs compressed down to a 101 byte blob.
Feb 25, 2022 10:39:45.721 [3780] Debug β PlayQueue: Added 46 items in 0.0 sec.
Feb 25, 2022 10:39:45.764 [8008] Debug β Completed: [192.168.1.44:49818] 200 POST /playQueues?own=1&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto&excludeFields=file%2Ctagline&uri=server%3A%2F%2F7c171af2ebf3f9cc9394acd95cefa3ec3b71027b%2Fcom.plexapp.plugins.library%2Flibrary%2Fmetadata%2F445&type=video&continuous=1&includeRelated=0&shuffle=0&repeat=0&key=%2Flibrary%2Fmetadata%2F452 (17 live) GZIP 46ms 9472 bytes (pipelined: 8)
Feb 25, 2022 10:39:45.865 [3780] Debug β Request: [192.168.1.44:49818 (Subnet)] GET /library/metadata/452?checkFiles=1&includeChapters=1&includeMarkers=1 (17 live) GZIP Signed-in Token (qw2my)
Feb 25, 2022 10:39:45.897 [3780] Debug β Audio Stream: 1849, Subtitle Stream: 0
Feb 25, 2022 10:39:45.901 [8032] Debug β Completed: [192.168.1.44:49818] 200 GET /library/metadata/452?checkFiles=1&includeChapters=1&includeMarkers=1 (17 live) GZIP 35ms 2727 bytes (pipelined: 9)
Feb 25, 2022 10:39:45.929 [3780] Debug β Request: [192.168.1.44:49818 (Subnet)] GET /video/:/transcode/universal/decision?directPlay=0&directStream=1&directStreamAudio=1&protocol=dash&fastSeek=1&path=%2Flibrary%2Fmetadata%2F452&session=wmzq6s9gy5r02xvqsb6aq1lw&mediaIndex=0&partIndex=0&mediaBufferSize=50000&hasMDE=1&subtitleSize=100&videoQuality=100&videoResolution=4096x2160&audioBoost=700&location=lan (17 live) GZIP Signed-in Token (qw2my)
Feb 25, 2022 10:39:45.930 [3780] Debug β [Transcode] Found session GUID of wmzq6s9gy5r02xvqsb6aq1lw in session start.
Feb 25, 2022 10:39:45.932 [3780] Debug β [Transcode] TranscodeUniversalRequest: using augmented profile Generic
Feb 25, 2022 10:39:45.932 [3780] Debug β [Transcode] Downloading document http://127.0.0.1:32400/library/metadata/452?includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=wjgbq5q4t1ekha3i6v34jsdt
Feb 25, 2022 10:39:45.956 [3780] Debug β [Transcode] Audio Stream: 1849, Subtitle Stream: 0
Feb 25, 2022 10:39:45.961 [3780] Debug β [Transcode] Codecs: testing aac_mf (encoder)
Feb 25, 2022 10:39:45.965 [3780] Info β [Transcode] [FFMPEG] - MFT name: 'Microsoft AAC Audio Encoder MFT'
Feb 25, 2022 10:39:45.969 [3780] Debug β [Transcode] MDE: Selected protocol dash; container: mp4
Feb 25, 2022 10:39:45.969 [3780] Debug β [Transcode] MDE: analyzing media item 787
Feb 25, 2022 10:39:45.969 [3780] Debug β [Transcode] MDE: E6 - Tisch 43: Direct Play is disabled
Feb 25, 2022 10:39:45.969 [3780] Debug β [Transcode] MDE: E6 - Tisch 43: media must be transcoded in order to use the dash protocol
Feb 25, 2022 10:39:45.969 [3780] Debug β [Transcode] MDE: E6 - Tisch 43: selected audio stream is not the first audio stream and direct play stream selection is not enabled
Feb 25, 2022 10:39:45.969 [3780] Debug β [Transcode] MDE: E6 - Tisch 43: no direct play video profile exists for http/mkv/mpeg2video
Feb 25, 2022 10:39:45.969 [3780] Debug β [Transcode] MDE: E6 - Tisch 43: no direct play video profile exists for http/mkv/mpeg2video/ac3
Feb 25, 2022 10:39:45.969 [3780] Debug β [Transcode] MDE: E6 - Tisch 43: no remuxable profile found, so video stream will be transcoded
Feb 25, 2022 10:39:45.969 [3780] Debug β [Transcode] MDE: Cannot direct stream video stream due to profile or setting limitations
Feb 25, 2022 10:39:45.970 [3780] Debug β [Transcode] Codecs: testing aac_mf (encoder)
Feb 25, 2022 10:39:45.974 [3780] Info β [Transcode] [FFMPEG] - MFT name: 'Microsoft AAC Audio Encoder MFT'
Feb 25, 2022 10:39:45.977 [3780] Debug β [Transcode] MDE: Cannot direct stream audio stream due to codec ac3 when profile only allows aac
Feb 25, 2022 10:39:45.978 [3780] Debug β [Transcode] MDE: The Mentalist - S1 E6 - Tisch 43: selected media 0 / 787
Feb 25, 2022 10:39:45.978 [3780] Debug β [Transcode] Streaming Resource: Reached Decision id=452 codes=(General=2000,Neither direct play nor conversion is available. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=4002,Not enough CPU for conversion of this item.)
Feb 25, 2022 10:39:45.979 [8008] Debug β Completed: [192.168.1.44:49818] 200 GET /video/:/transcode/universal/decision?directPlay=0&directStream=1&directStreamAudio=1&protocol=dash&fastSeek=1&path=%2Flibrary%2Fmetadata%2F452&session=wmzq6s9gy5r02xvqsb6aq1lw&mediaIndex=0&partIndex=0&mediaBufferSize=50000&hasMDE=1&subtitleSize=100&videoQuality=100&videoResolution=4096x2160&audioBoost=700&location=lan (17 live) GZIP 49ms 652 bytes (pipelined: 10)
Feb 25, 2022 10:39:46.854 [8032] Debug β Completed: [192.168.1.86:57654] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (17 live) TLS GZIP 20017ms 5 bytes (pipelined: 115)
Feb 25, 2022 10:39:46.887 [4328] Debug β Request: [192.168.1.86:57654 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (17 live) TLS GZIP Signed-in Token (qw2my)
Feb 25, 2022 10:39:46.887 [4328] Debug β Content-Length is -1 (of total: -1).
Feb 25, 2022 10:39:48.917 [8032] Debug β Completed: [192.168.1.44:49696] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cplayqueues&timeout=1 (17 live) GZIP 20004ms 5 bytes (pipelined: 76)
Feb 25, 2022 10:39:48.932 [4328] Debug β Request: [192.168.1.44:49696 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cplayqueues&timeout=1 (17 live) GZIP Signed-in Token (qw2my)
Feb 25, 2022 10:39:48.933 [4328] Debug β Content-Length is -1 (of total: -1).
That happens with the same file ( itβs an episode ripped with makeMKV from a DVD). And audio has codec: AC3 Stereo, which usually work.
When I turn transcoding ON, then both tracks work but I get transcoding for the whole file? And no direct stream? I donβt get it whyβ¦
With the other movies itβs a bit different problem, only difference is that the German track there has AAC Stereo codec and they donβt even work when transcoding is turned on, but the English track with ac3 works still!
Hope you can help me!
