Plex Pass - Extras not populating. PLEASE HELP.
Just bought a plex pass over the black Friday holiday and can not get extras to populate. I’ve tried everything. Was a little disillusioned to find that even as a paying plex pass customer -there is no direct support for me with this issue and I am left writing a question here and hoping.
-I am using the most up to date version of server.
-I have followed the instructions in the FAQ for setting up both the primary and secondary agents.
-I have restarted and re-logged in to everything.
-I have tried loading new media into the database as well as force refreshing and unmatching/rematching. I have also made sure to do this with movies that I know have extras because a friend’s server with plexpass shows them as such.
HELP.
And just to clarify - this issue is at the server and not the device client level. The extras will not populate.
“-I have followed the instructions in the FAQ for setting up both the primary and secondary agents.”
so how do you have it set up
Hey BigWheel… thanks for finding my post.
I have switched both (PLEX MOVIE) and (THE MOVIE DATABASE) to “Find trailers and extras automatically (Plex Pass required)” as instructed. I then restarted the server software including logging it out and back into the account. Still nothing.
did you hit refresh all after you did that?
can you copy the media xml from one of the files into here ( you may have to copy into a text file an upload that)
I have attached the xml from my library. I chose this particular one because I know from access to a friend’s server that this movie does in fact have automatic extras available. None currently populate on my server though.
I have NOT hit “Refresh All” yet. I have tried it on specific movies.
But I’m open to it if its necessary. Just have a large library and didn’t want to light that candle unless absolutely necessary.
yeah that looks fine. a refresh on a single item can should get them. Can you grab the imdb agent log. com.plexapp.agents.imdb.log after hitting refresh on BFG.
also would you mind taking a screenshot of your agent settings. ( i’m sure they are fine but sometimes we all forget to check something )
