Server Version#: 1.41.3.9292-bc7397402-x86_64_DSM7
Player Version#: 1.105.2.269-12a32491
MacOS (Sequoia 15.2)
When I run Plex player on Mac, I get a popup telling me I’m not connected directly to the server (on my synology, hard-wired on the network) but via Relay.
Can someone tell me what to look for or how to make sure Plex Player can connect to my server directly? My Mac is connected by ethernet, via a NetGear switch, to my Synology in the same room, so it shouldn’t be having any issues.
And there doesn’t seem to be a simple way, in settings, for me to tell Plex Player to “retry local connection” or troubleshoot this?
I believe when running Plex on my LG TV or on my PC (in another room) that those connections are going direct to my server, as expected. So I think it’s just the Plex Player on MacOS that’s having issues for some reason?
Would love to know how to make sure all direct local connections are working fine.
Anyone? Please? I’ve disabled Relay via the Plex Player and now my server cannot be accessed. It’s on the same network. It’s on the same subnet. I’m logged in via the web frontend to my Synology. I uninstalled the Plex Player app and re-downloaded it, and re-signed in, and it’s still not seeing my local server.
Hi, thanks so much for the response… logs attached.
My TV, iPad, phone, PC in another room… can all connect to the server directly (I believe). But the Plex app on MacOS just… wasn’t connecting directly, and now can’t see it since I turned off Relay connections! It’s wired to it, and it’s in the same room!
(I’ve omitted any older modified files to keep ZIP under 8MB upload limit).
Alright immediate followup. Just re-ran Plex app on MacOS. It bombed out immediately. Hit “Reload” and it opened up properly… and… connected to my server.
I just don’t know HOW it’s connecting. It says “Remote” under the server name in menu bar when I click the ‘reveal’ arrow next to it, and in Settings > Remote Access it’s showing me “Private IP, (green left arrow), Public IP, (green left arrow), Internet.”
Does that mean Plex App is CURRENTLY connecting “remotely”?
I have noticed recently in MacOS you sometimes have to allow applications access to the local network - usually there is a prompt to allow/deny and you can view the apps in - MacOS System Settings - Privacy & Security - Local Network
This worked for me with plexamp but I don’t use the plex for mac application to check this
Thank you so much, to both of you, for helping! It feels so obvious now, but of course these things are only obvious when you know the answer. And now we do
