Plex/Plexamp Chromecast not displaying Artwork on Wiim Ultra screen
Hi there,
I am unable to display Artwork through Chromecast, using Plex or Plexamp, on my Wiim Ultra screen, from a NAS local library composed entirely of flac files, that include a “folder.jpg” for each album.
I also tested embedding the artwork in each track, in case this could solve the issue, but I have had no success.
After contacting the Wiim support team, they blamed Plexamp and stated the issue was not at their end.
I tested casting on a TV with Plex and Plexamp, and was able to see the Artwork.
I tested with the mobile app Symfonium, and the artwork is displayed correctly on the Wiim Ultrac, through Chrome cast.
I find all this quite confusing and difficult to understand where the issue may be, based on those tests.
Is anyone able to display artwork on a Wiim Ultra around here?
Thank you in advance for your help!
Bump!
I am surprised no one has seen this issue or know something about it.
Is anyone able to display artwork through Chromecast with a DAC other than the Wiim ultra?
Thanks.
It’s not just WiiM Ultra, but any chromecast / cast audio endpoint. The Plex’s chromecast audio implementation is half-baked and hasn’t been updated for ages. Not sending the artwork is one of the things that is not implemented.
When you cast to a TV / Chromecast video, it works a bit differently.
I have the same issue. Other apps work fine and display artwork through Wiim Ultra Chromecast but PlexAmp doesn’t. Hopefully the Plex team will review the Chromecast audio implementation. I also have issues like music disconnecting for 2 seconds from time to time when streaming from PlexAmp via Chromecast Audio (it’s not the network as I use the Ethernet connection for both Plex Server and Wiim Ultra). Do you have any short disconnects when streaming from Plex via Chromecast or Wiim app?
Thank you both for your input.
It is a sad state of affair, but at least now I can confirm where the issue is coming from.
You would think that sending artwork is fairly straightforward to implement… It is a bit of a let down that Plex can’t be bothered doing it…
@undragon I haven’t had this issue exactly, but at first, through Plexamp chromecast, any song would start and stutter on a loop after a few seconds.
This was resolved by updating to a beta firmware that the Wiim support team provided, after I contacted them.
Are you running the latest firmware?
It may be worth opening a ticket with them.
