Plexamp transcoding on local network using Chromecast
Server Version#: 4.141.0
Player Version#:v4.11.5 (Plexamp)[both on Android and iOS]
I got a Wiim Ultra to replace one of my Pros. It’s been great and I have phono functionality now. I am, however, having issues when streaming Plex through Chromecast. Plex is transcoding my files playing within the home network on the Ultra. It isn’t doing this with my Pro that I have upstairs. It’s doing this from either Android or iOS. If I use the Plex integration in the Wiim app I can’t tell if it’s direct playing as it doesn’t show up on my Plex server as playing from the server. Any help or guidance to change the Chromecast settings would be great. Right now it’s taking FLAC files and transcoding them to OPUS 256 kbps.
I am able to use Symfonium and play files with no transcoding. So, this has narrowed it down to Plexamp feeding the system and telling Plex to transcode on the Wiim Ultra. I’m hoping this can be fixed so that I can continue using Plexamp rather than relying on yet another app.
I even tried editing the settings in the Chromecast.xml file to:
This works for about 30 seconds before it crashes Plexamp.
Thanks.
