Sorry, don’t follow your last sentence. Are you saying I should restart QNAP? Or that there ought to be a function for Plex to auto-restart itself?
The 44mb log directory I zipped up was before I restarted PMS. You said the log files were missing in there, but I was looking at them right up to 22:53…
ETA: I think I see what you’re saying. There was no additional activity logged between the crash and when I manually restarted. Maybe an auto-restart routine would help get it back up and running.
The bigger question (for me) is what is causing the crash in the first place? Prior to these issues about 2 months ago - I had a rock-solid, hands-off Plex server. Now, if I go more than 48 hrs without some family member or friend complaining about the server, it’s a long time.
On QNAP, if PMS stops for any reason, I don’t automatically restart it.
On Workstation Linux, it is automatically restarted immediately (up to 3 attempts).
It might be possible for me to do the same on QNAP.
Should it detect PMS has halted for any reason, within reasonable tolerance,
Sounds reasonable - certainly better than it is now. However, even better (or in addition to that) would be figuring out why it’s becoming unresponsive/crashing in the first place.
I noticed that in the crash report log, it’s failing to send the dump file to sentry.io. Is that relevant, or can you recover info from the logs you see now?
I agree entirely - There is no reason for it to behave as it is currently. Any work I might consider would be a) stopgap b) done in the same manner as traditional desktop Linux is - obeying those constraints
Ok, I’m just hoping you have enough from the logs to help track down the gremlin. If not, let me know how else I can help troubleshoot.
Also, since there seems to be some kind of miscommunication (at least on my system) between how the App Center sees the running processes, I’m hoping that whatever trigger you use to determine PMS is really no longer running, uses something other than the status as reported by the App Center…
Just another quick question… does my discussion with you initiate the bug fix with engineering, or do I need to reach out to them separately? Also, if you could go back and remove my log/code that contains my email above, that would be great.
You’re very welcome. You’re not alone (unfortunately) but thanks to the data, they can usually find the problems quickly and start working on resolving them.
