Plex remote access issues - cannot connect securely
@OttoKerner
May I also ask for a check on my certificate? I seem to also have issues connecting to my server and have yet to find a fix.
May my certificate be renewed? Cannot access my Plex server outside my local network
You are not affected by this particular issue.
Ok, thank you for checking
Done. Stop and restart your server please.
I’ve currently got this issue, if you could check mine also?
I think I have this issue as my cert has expired
Indeed. Please stop and restart your PMS.
Hey, pretty confident I’m having this certificate issue as well. Hope you can help!
Correct. Same as above.
All fixed! Thank you :grinning_face:
I am having the same issue
Yes. Please stop and restart your Plex server.
Great! It’s working again. I had tried everything. Thank you so much for your help.
I as well am having the same issue. If you can do the same for me as the others, I’d greatly appreciate it!
Done.
You fixed it. You’re a champion! I hope you’re getting compensated for helping all of us. <3
Can you sort it for me please?
Done.
