Plex remote access issues - cannot connect securely
Cheers!
@OttoKerner could you check if I’m affected by the issue? Thank you
You are not affected by this particular issue.
Can you check mine as well please. Been racking my brain the past couple days.
Done.
So fast. That fixed it. Thank you very much.
Hi, could you check mine please?
Could you please check mine as well?
[mod edit] Not affected.
I am having this issue as well, I can access externally through web browser but plex apps don’t work
I also have an expired cert and my server Plexie cannot renew it’s certificate.
CERT: Error acquiring new certificate: Failed to upload CSR: 429 message="API rate limit exceeded"
Hi, I’m having the same issue:
Can you please reset? I’m able to connect via browser pointing directly at my IP, but not via apps (both private and public).
Thanks.
I am also having this issue
[mod edit] not affected
Hi there, I’m wondering if I have the same issue. Can you please confirm if my certificate needs renewing?
Lost remote access as well, please refresh
Can you check mine please. I seem to have lost access yesterday also.
I think my remote access is being affected by this as well.
Can you please check mine too? I’m having the same issues as others here. Thanks!!
I’m having the same issue. Can you please check mine?
@OttoKerner I’m impacted by the same issue. Can you please check my certificate? Given how widespread this seems to be based on recent forum threads/posts, is there any way for your team to detect and resolve certificate renewal issues without individual reporting?
I really hope I am being affected, because I have been losing my mind for the last few hours trying to figure out why I could access literally every other service I run, but Plex wasn’t letting me.
