Plex remote access issues - cannot connect securely
Unfortunately the same certificate issue has returned.
PMS version: 1.43.3.10896-cb3ebc72d
Platform: Debian Linux LXC
Current log:
CERT: Certificate did not exist, fetching a new one.
Certificate CSR request returned HTTP 429.
CERT: Error acquiring new certificate:
Failed to upload CSR: 429
API rate limit exceeded.
cert-v2.p12 is currently missing again.
The server itself is online and local HTTP access works.
Could you please check/reset the certificate/CSR state for this server again?
Thanks.
It’s not the certificate remote access is totally down at the moment
Issue with plex direct DNS according to reddit
Mods, can you please check my Account, been chasing my tail for weeks..
Could I have my certificates checked? Remote access has been down for a few days now
[mod edit: please stop and restart your server now.]
… will a MOD please check my certificate… rmt access still down…
Hi, my QNAP Plex server is affected by the stuck certificate/CSR issue.
Server version:
1.43.4.10781-05b8fa770
Server name:
homenas
Machine identifier:
7e97629a93f8522a75b91e9876b91777ec27c358
Remote Access reports fully accessible and external HTTP access on port
32400 works, but app.plex.tv cannot connect securely.
PMS retries every 20 minutes and consistently receives:
HTTP 429 response from PUT /certificate/csr?reason=missing&invalidIn=0
CERT: Error acquiring new certificate: Failed to upload CSR: 429
Could a moderator please reset/revoke the stuck certificate state for this
server? I will perform one clean stop/start after you confirm the reset.
Thank you.
[mod edit: please stop and restart your server(s) now.]
Hi, can a mod please check my certificates as well? Remote access has been down for me for weeks now.
Thanks!
Edit: I restarted, and my remote access is still not working. Is there anything else you can do to assist? Thanks for your help in advance.
i believe i am having this same issues on my server as well
I’m having the same issue. Can you please check my cert? Thank you.
I am unsure if I am having the same issue but my remote access to both my servers stopped working, I was somehow able to get my laptops remote server working by reissuing the port forward for it, but my desktop is still unable to be remotely accessed, please help
I’m unable to connect to my server remotely. I typically use tailscale, but that doesn’t seem to be working anymore for me to access on cellular or other wifi networks.
Same problem is happening again!
Hi there, recently moved and remote access is broken again. Can a mod check this out for me? Thank you!
