Server Version#: 1.15.4.994
Player Version#: 3.102.0 (Web Client)
For whatever reason, I cannot get Plex Remote Access to work on my PC; it had worked in the past briefly and nothing has changed on the PC. It is a Windows 7 64 bit PC.
Below I’ve included pretty much everything I’ve done and seen. Anyone have ANY clue as to what is going on?
if you have 32401 in the manual specify port field then you can’t use some other port. It will only use that for external. If you are using 32400, put 32400 in that field.
that nat gaming rule screenshot seems like it is missing a bunch of stuff normally found in port forwarding. can you take a screen shot of where you actually enter the values.
If you look at those instruction I linked above step 7 says there should be a “needed by device” option somewhere on the “Nat and Gaming” page to tell it which computer on you network to forward it to where you likely select it’s IP address or network name or similar
