@nurbles said:
Restarting the server is very difficult from 600 miles away. I’m traveling and this update took my plex access away. I wish there were a way for “Plex Central” to cause my server to restart, perhaps by having it do an update to the software or something (mine is configured for automatic updates – that’s what triggered the problem for me in the first place, I suspect.)
@nurbles: install teamviewer on the server. . .its been a lifesaver for me. . i’m constantly having to fiddle w/ the stupid software when i’m miles away.
My Remote Access goes from green to red several times a day. I have to manually reconnect. I was able to set the servers IP as static, but I’m running into some difficulties getting my router to set the port forward. Has setting a Port Foward fixed this issue for all of you? If so I’ll keep trying.
I’m having aterrible time as well, where as it used to work just fine for ages - (months on end) but it NEVER is green in server settings even when others can connect to my plex server while offline. I wanted to use ombi with my plex server but it can’t ever connect to it either.
