Plex screen saver kicks on if I pause or stop playing too soon
is there a way to force the screen saver to wait longer prior to starting up? I am running plex on a windows machine and use the Plex Roku channel to watch shows and movies. if I pause and run to another room for something and come right back (10 seconds maybe), the Plex screen saver has started and I have to hit a button to make it go away and then put my pin in again to get back into the system. Is there a way to stop this screen saver from coming on?
Thanks,
The screensaver timeout is based on your global Roku screensaver settings. You can increase the timeout up to 30 minutes. The lock screen is also based on this setting, so if you disable the screensaver, the lock screen will default to 5 minutes.
Thank you so much. I never thought about the Roku screen saver. I have been digging around in Plex trying to find something. I never gave it any thought that it would be tied into the Roku screen saver. Thank you so much!!
