Server Version#: 1.18.7.2457
Player Version#: 4.26.1
Hello!
I have an issue where movie X with part 1 and part 2 are seen as the same movie by plex. How do I make plex see them as two different movies? I found this:
Okay, so I have the following two titles in my movies library:
When ripped from their DVDs, they yield two separate parts each of one whole production. Because of this setup, I don’t think Plex knows what to do with the metadata from TheMovieDB. Plex will acknowledge in “Get Info” that there are two separate parts being associated with each listing, and the metadata will show the combined total runtime, but in both cases it will only play the first part of each while not otherwise ackn…
where @NewPlaza sent a reply with a link that do not work anymore…
you don’t need a link if you just read the post.
-part1.mkv
-part2.mkv
will ‘merge’ files into one
if you remove or change so it is not -part1, for example part 1, then they should not be combined.
if you need to uncombine something click the 3 dot menu and select ‘split’.
btw here is the link @ https://support.plex.tv/articles/naming-and-organizing-your-movie-media-files/
section Movies Split Across Multiple Files
system
Closed
May 26, 2020, 4:12pm
5
