DSM version 7.1-42661
Model DS920+
Plex Version 4.43.4
PC Windows 10
I can see my files in the proper folders when plex is launched from the Synology NAS server. When I open Plex on another device (such as a firestick), it sees the server however there is a triangle with an exclamation point in it. I can do nothing to get into it. I assume this is a permissions issue but have had no success in getting it to work. How do I proceed?
Also, In the permissions tab in shared folders I have a “Plex” option but not a “PlexMediaServer” option. “PlexMediaServer” is found under “System Internal User”, not “Local User”. Is this correct?
If the server name (leftmost panel) has a triangle over it, then it isn’t being seen / server isn’t talking to you.
For Permissions in DSM 7 – You want PlexMediaServer (we had to change all the names for DSM 7 )
I put that popup at the end of installation but I can’t tell you how many people just ‘blow right through it’
