Plex Series agent not finding show
I couldn’t find a recent post on this subject that wasn’t already closed or did not show a solution. Maybe it’s just me…
I have a series “Biography” on my server that the Plex Series scanner doesn’t find. Of course when that scanner is enabled you can’t choose what agent it uses.
If I change the scanner to TVDB it recognizes the series just fine. This isn’t some new show that hasn’t been copied to Plex yet: Biography - TheTVDB.com
If I leave the library with the TVDB scanner of course I get this constant nag message that I need to “upgrade libraries”.
Grrr…
is there a solution for this?
Fix Match using the TVDB ID tvdb-70730.
https://support.plex.tv/articles/201018497-fix-match-match/#:~:text=of%20the%20search.-,Tips,-There%20are%20a
