Server Version#: 1.41.0.8994
Player Version#: 1.102.0.230
Some questions…
Sorry, when its stupid or RTFM…I am starting with Plex (again) and I dont want to give up, because something isnt working or different to my previous system.
1.) In Plex Server administrator, can I see which media files are behind a movie/serie? I cann see only the movie titles, but not which file are behind of this (RFS: its easy when Plex has find something wrong, which is the original file, then I will know what it should be
2.) In Series are some (minimum 1) directory with a series missing. 30 are found, 1 not. And I only know this by coincidence. Can I list directories which are not listed in Plex?
3.) How do I add this missing series manually? (In e.g. Kodi, it is included, also Im using TinyMediaManager to create nfo files with all informations
4.) In one series (4 seasons, each season has 10 episodes), it is listed as Season 1 30 episodes, season 4 10 episodes. Why that strange sorting? How can I change this to season 1 10, season 2 10, and season 3 10.? The naming should be correct (as before, in Kodi it is listed correctly)
5.) In my NAS I have folders “Movies” and “Series”, each with subfolder “4k” and “HD”. When I created my libraries the movie librarie is ok (Kodi/movies), no need to add subfolders. Doing the same for Series (Kodi/series) and the result is a mess. There is e.g. the 1st series listed “3 Body Problem” which is in 4K (subfolder 4K), this has suddently 63 episodes (original 8) and a lot of other series includes as seasons. Totally messy. If Plex cannot work with subfolders, why this is working in Movies? Or what happens here? The same for a series which is the 1st alphabetical in the HD subfolder…155 episodes - from different other series in the HD subfolder
I think to No 5…I can add the subfolders seperately into the TV Show library. Maybe this will work better. Just trying now
