After a power cut my Plex server became unaccessible via web app. I can sign in but the server is unreachable.
I have tried deleting all system files and reinstalling fresh with the latest package from the website. Install goes fine but when I go to open Plex from the list of packages in the Synology control centre I get:
400 Bad Request
The plain HTTP request was sent to HTTPS port
I can see the server in the web app but has a red triangle next to it and gives the error:
app.plex.tv is unable to connect to “EOTAnas” securely
I’ve spent the last hour researching this problem but to no avail! Can anyone point me towards a solution? Ta
I’m running 1.29.1.6276-7000 on Synology DS218 with DSM 7.1-42661 Update 4
Hello, thanks for the reply. I first tried uninstalling with the keep option but no success. I then did a full uninstall, manually deleted all Plex files on the file explorer via Synology quick connect and used the claim token option when re-installing. The server then shows on the web app but with the little red triangle.
I have just tried logging in via Brave instead of Safari, no luck. I’ll attach a screenshot.
Also other strange things are happening, under settings it says I am logged in to my normal email address account but in the top right it says I am logged into an account I have never heard of. Ill attach another screenshot. Any thoughts?
Looks like we’re getting closer to a solution.
Ive just signed in on the local server and instead of a red triangle I’m getting a green padlock.
Under remote access I’m getting
Not available outside your network
Your server is signed in to Plex, but is not reachable from outside your network.
Hi, I’m afraid I’m back again… It worked like before a couple of times, then back to the old no connection again with the red triangle. Now my server isn’t even showing.
Any idea whats going on?
