That sounds weird. If the key is missing from the registry, it means Plex is using the default path. In which case adding the backslash is not necessary.
Yup. Tried it and it worked! Thanks!
Worked for me too thanks
Hi, how do I fix the same issue on Nvidia Shield?
Hi!
How do i fix the same issue on FreeNAS DB?
See also:
Seconded
Iâve been having this problem and found if I log in on my plex app on ios it allows me to update the server which fixes it.
