Server Version#: v1.15.2.793-782228f99
Hello,
Changed location from an apartment to another. Once moved here apparently it tells me that plexmediaserver service is started, on the other hand I can not access the GUI.
ISP provider gives both IPv4 and IPv6 through their router, though this shouldn’t impede the server loading at least locally.
Looked though the log and all I can find is a curl error:
Aug 01, 2019 13:35:48.162 [0x80c247900] ERROR - Error issuing curl_easy_perform(handle): 6
Aug 01, 2019 13:35:48.163 [0x80c247900] ERROR - HTTP -6 downloading url https://meta.plex.tv/t/theater?language=en&subtitleLanguage=ro&redband=0
Aug 01, 2019 13:35:48.163 [0x80c247900] ERROR - IVA: Error downloading trailers for source 1.
Aug 01, 2019 13:35:54.433 [0x80b29b500] ERROR - Error issuing curl_easy_perform(handle): 6
Aug 01, 2019 13:35:54.433 [0x80b29b500] WARN - HTTP error requesting GET https://plex.tv/servers/98445e098f1fcebfaeb8ca0fcffb05cdb8cc9f5c/sync_lists?auth_token=xxxxxxxxxxxxxxxxxxxx (0, No error) (Couldn’t resolve host ‘plex.tv’)
Aug 01, 2019 13:35:54.433 [0x80b29b500] ERROR - Sync: unable to download sync lists from https://plex.tv/: -6
Aug 01, 2019 13:35:54.433 [0x80b29b500] WARN - Sync: either our myPlex credentials were wrong, or myPlex wasn’t available
Aug 01, 2019 13:35:54.433 [0x80b29b500] DEBUG - HTTP requesting GET https://plex.tv/api/v2/user/privacy?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Aug 01, 2019 13:35:54.553 [0x80b29ce00] ERROR - Error issuing curl_easy_perform(handle): 6
Aug 01, 2019 13:35:54.553 [0x80b29ce00] WARN - HTTP error requesting GET https://plex.tv/api/v2/release_channels?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx (0, No error) (Couldn’t resolve host ‘plex.tv’)
Aug 01, 2019 13:35:54.553 [0x80b29ce00] DEBUG - [AutoUpdateRequestHandler] Using cached data for update channels
Aug 01, 2019 13:35:57.439 [0x80c246500] ERROR - Error issuing curl_easy_perform(handle): 6
Aug 01, 2019 13:35:57.860 [0x80afe2800] ERROR - Error issuing curl_easy_perform(handle): 6
Aug 01, 2019 13:35:57.860 [0x80afe2800] WARN - HTTP error requesting PUT https://plex.tv/devices/98445e098f1fcebfaeb8ca0fcffb05cdb8cc9f5c?Connection[][uri]=http://192.168.100.3:32400&httpsEnabled=1&httpsRequired=0&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx (0, No error) (Couldn’t resolve host ‘plex.tv’)
Aug 01, 2019 13:35:57.860 [0x80afe2800] WARN - MyPlex: Updating device connections failed, retrying in 10 seconds.
Aug 01, 2019 13:35:57.860 [0x80afe2d00] DEBUG - MyPlex: Updating device connections (from timer: 0)
Aug 01, 2019 13:35:57.861 [0x80afe2d00] DEBUG - HTTP requesting PUT https://plex.tv/devices/98445e098f1fcebfaeb8ca0fcffb05cdb8cc9f5c?Connection[][uri]=http://192.168.100.3:32400&httpsEnabled=1&httpsRequired=0&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Does anybody have any clue?
Thank you
