So I reset my DS218+ today which wiped the DSM install and re-installed it. But for some reason, once I re-installed Plex Media Server, all my movie libraries and settings are still there. I thought the only way to keep those settings is if you install a new version of PMS on top of an existing one. How is it that they are still there after a wipe of DSM? I saw no “plex” folder on file station after the wipe. Not sure where it could have been stored.
I keep the software and your metadata (Library) in separate places to allow you the freedom to change versions easily.
To completely remove everything and start over from scratch
- Uninstall package
- Control Panel - Shared Folders - Delete the
Plexshare - Control Panel - Users - Delete user
Plex - Restart
