Server Version#: Version 1.23.5.4862
Player Version#: Web.
So I have a TV Shows and a Movies Library with a couple folders in each (amongst others but these are the problem children).
For some reason it is showing the Movies Library under the Library tab in TV Shows AND in Movies as you can guess going forward this would make the TV library kind of unmanageable as I can’t edit anything. Every other tab is correct, Recommended and Collections is just fine, only Library is broken.
The Libraries look correct on the PC player and also on Android, i’ve tried on a couple different PC’s so I don’t think it’s a browser Chrome is what i normally use, I tried another browser Edge, as a last resort i created another user - that user sees the library correctly. As does another account I have shared the library with.
Kind of at my wits end, i’ve used plex for years now and only just bought plex pass and now it’s kinda broken.
I’ve seen of occasional reports of this problem. Somehow some bad data is being saved, causing the tabs to get “stuck”.
If you can ever figure out how to reliably reproduce this behavior please do let me know. I’ve been having tons of trouble reproducing it (despite seeing reports of it, so I know it’s a problem)
