Plex stopped working on LG TVs
Working again!!! No need to update anything
Working again for me too!! Didn’t have to anything else to fix, despite previously rolling back etc…but working fine now on latest release
Yep…mine works now also…3.13.16
Still doing it here after server update to latest.
I’m having exactly same issue on Samsung TV with the Plex app not able to play any videos hosted on my local servers or videos from web, etc.
May be a DNS issue - not sure what gives…
Broken Also on Sharp/Hisense TV. Using DLNA seems to work for short term. How long should we expect to wait for a fix? Days, weeks, months?
End Of 2018. and this issue is still
At large. No wonder no one I know refuses to purchase a pass. Wow. Buy a Plex pass and have it not work on your TV. This almost funny
Has this been fixed yet… its 2019… the app on my lg TV I just bought is from 2016… I mean I can run it through my fire TV, but ide rather have it working on my tv
Plex app not working on my LG TV as well…
Not working on B7
So after going through the video settings I noticed that the H264 level was now set at 5.1 (recommended) so I changed it to 4.0 and tested a video that did not work before the change and voila! It started playing so maybe this could fix your issue as well good luck.
This pointed me in the right direction, I unchecked ā€œAllow Direct Playā€ and ā€œAllow Direct Streamā€ and that corrected the issue. Now what problems unchecking those options will cause has yet to be determined.
Congrat Plex:
Lg webos2 fu.ked resolution for App…
And for this fuc.ed update i resett fu.ed tv to default… Aplaud!
Exactly the same here happened today
Today PLEX does not work on my LG WebOS 1.4.0-2529
the reason is that this is a big blameless
You release an update that splits everything.
I really hope you will solve it soon!
In the meantime, Lg users have the smartshare…
Plex is no longer working on 2017 LG tv. Any update on when this will be fixed?
It works fine on at least three of my users 2017 models.
You’re going to need to provide far more than it’s no longer working.
Ok everyone, I found a fix. Mine was working until today. The app stopped working and I went to the support menu in settings and selected ā€œInitialization of appā€ and let it do it’s thing. Started Plex again, authorized the TV, and it started working again. Hope this helps others.
Further to the last fix…
Log in to Plex on PC or Mac. Remove the Authorized Device causing the problem, (LG TV). Relaunch the App on the LG TV and reauthorize with a new PIN.
This worked for me.
