You have dual 10 GbE links to your switch but want to run 1 GbE as the primary ?
Single interface per subnet is how this needs to be done because of QNAP limitations.
You got lucky until now but QuTS / QTS 5 changed a lot in the stack.
I have 2x 10 GbE NICs and 4x 1 GbE NICs in my TVS. I don’t use the 1 GbEs at all.
20 GbE to the core switch for everything here is plenty (even with all the support, development, and testing I do)
It’s a good point. When I got the 1688 a few months ago, i had set up the default interface to be a stock 1 GB ethernet interface. I’m using my Unifi Aggregate switch for 10 GB interfacing which I already have. I didn’t make it default since I wasn’t sure how good or stable it was going to be but it’s been great so far. So I really don’t need the old interface. I can try to go without it and see if there is any difference.
The Unifi equipment gives the QNAP the same addresses through DHCP by configuration. All I have to do is disconnect and either ask the control panel to change the default interface or just reboot without it.
Last night was the first and only time the memory issue has happened, and this is the logs from after I rebooted the NAS and started-stopped-started Plex from the QNAP apps section. After attempting to start it the first time I got an error stating it hadn’t been shut down correctly before.
Sorry for the delay. I took a break from debugging to lie down for a short bit after rebooting the NAS after removing the gigabit interface, setting the bonded 10gb link as default and rebooting the machine. When i returned, the machine was up but not talking to anything. I reconnected the gigabit line again and was able to get control of the NAS again. (pinging the bonded link was failing even though the Unifi dashboard said everything was fine). Will report back when the thing comes back from a POST.
An update. I finally have it configured so that the only hard interfaces are the dual 10gb Ethernet ports that are bonded back to the Unifi. It’s communicating well and is now the default path back to the Unifi router. The Interface 1 connection is disconnected and not in the configuration. I did have a Thunderbolt connection back to a Mac sitting next to the QNAP which is also disconnected now.
And so far, the PMS is still not speaking to anything. On the other hand, my two VMs (Win Server 2019 and Ubuntu Linux) are both communicating through s virtual switch on the QNAP as configured. Roon Server is also communicating properly through the network. Everything seems to be working except for Plex.
Today my plex was unreachable (same version I downloaded on 12/12 from plex.tv 1.25.2), I stopped it on QNAP, restarted it, zipped logs folder. It’s here below, thanks @ChuckPa .
I’ll see if I can play around a bit after the holiday, thanks! However, I may also just delete all the NFOs, they are just old files I don’t even need anymore that basically pointed to TVDB IDs =).
