Server Version#: 1.18.7.2457
Player Version#: 2.1.3
PlexPass member
This is what happens
Out of the box when i bought this TV it worked fine no issues but as soon as i turned off TV i came back and i get error 337 Check connection via wireless and wired. The temp fix is to factory reset TV and link plex to TV and works but starts all over again if i shut TV off again.
I have 10 days to return TV suggestions?
Just for the heck of it i tried the browser and no issues whatsoever…
If you’ve a Netflix account, check the network connection using their app. Settings -> Help -> Check Network Connection. It checks connectivity and download speed to their servers.
Regarding the Plex app, instead of resetting entire TV to factory defaults:
Delete the Plex app from the TV.
Power off the TV.
Pull the power (remove from mains) for ~30 seconds.
Restore power.
Power on, re-install and re-authorize app.
Verify app version in Plex app settings. Current version is 4.27.1.
The above makes sure you have the current version of the Plex app.
You should only have to do it once.
Try it, see if it helps, and report back.
Note 1: The wired Ethernet port is 100 Mbps. The 5GHz wireless supports 802.11ac and is faster than the wired port if you’ve a solid signal. It can help when playing high-bitrate videos such as 4K HDR in Plex.
Note 2: The reason for removing power is to fully stop any background processes. Turning off the TV only puts it to sleep, which does not necessarily stop/unload any running apps. This can also help if the TV or Plex app becomes unstable. It only takes a minute and can potentially save having to reset to factory defaults or removing/re-installing apps.
OK There are no updates on the TV Plex APP 2.1.3 is latest in LG content store and I do not have Netflix. I tried using the LG browser with no issues at all. I do have a Amazon prime account. I did have a Samsung Q60DR and the plex app had 0 Issues Unfortunately i returned it to buy this LG TV Due to Size and price point
Ahh ok Copy that. What makes me scratch my head is if i Reset TV completely and reinstall plex and connect to internet it works perfectly but soon as i shut off tv and turn on to watch it doesn’t even allow app to do anything other than say it can’t connect due to connection error 337
I may have my understanding of the correct setup for a LG TV app but it needs a Server locally. A dumb/empty Server which is sharing with your Server at home I believe will give you the best results. Add your Laptop IP to LG TV manual server.
Remote viewing is normally via a browser unless sharing
