Couple weeks ago I’ve faced a strange problem with my Plex setup: no matter what audio track is selected - every video plays with Russian track, and when you change the track in the Plex player - just nothing is changing.
It only changes if I enable any subtitle but in this case video starts buffering and than crashes.
I have a latest Plex server installed on MacOS and Plex player on Samsung smart tv (v 3.1.0).
I suspect it has something to do with the update of the tv app on 06/30/2017…
I believe you need to separate your preferred Languages and take careful not of settings in each Library for Languages .
I’m not quite understand what you mean…
My preferred sound language is set to English and it has never been changed.
I think the problem is in the TV app - it requests incorrect streams form server, but reinstallation hasn’t helped.
Now I’ve got it, but as I said - the English language is set as default everywhere.
Even in Plex player is says that “English” is selected but it plays Russian stream.
Same problem here on one device stuck on French. I guess Microsoft doesn’t care about this kind of issue. I will advise if I find a solution other than “reboot and try again”.
