Server Version#: Docker 1.32.4.7195
Player Version#: 4.108.0
Hi All,
I recently started to receive an error when trying to play some files. It seems to fail more when the file is closer to the end…
I noticed this error coming up in the kernel logs
[345303.878578] Plex Transcoder[1800892]: segfault at 28 ip 00007f5169b681c2 sp 00007ffc9372f120 error 4 in libavformat.so.59[7f51699e7000+1fe000] likely on CPU 16 (core 9, socket 1)
[345303.878596] Code: 89 ef e8 f1 a8 07 00 45 31 ed 85 c0 41 0f 94 c5 45 85 e4 74 60 83 bb 80 05 00 00 00 74 57 48 8b ab 70 05 00 00 48 89 6c 24 08 <48> 8b 7d 28 e8 65 a5 07 00 eb 62 48 8b bb 80 00 00 00 8b 93 7c 05
I have also attached the server log with debug. (for some reason, verbose is also showing). See attached.
Does anyone know what it might be or how to t-shoot?
Plex Media Server.log (167.8 KB)
Hmm, this seems to happen often when i get close to finishing at movie or show. How odd as i am not even transcoding, i am direct playing. It also seems to mostly happen if i have subtitles turned on??
anyone have any thoughts
Are you using a smart tv as your player? Samsung or LG? It sounds similar enough to this post you should probably take a look.
An employee asked for logs there so if it sounds like the same issue maybe drop yours in there also
Hi @JaysPlex, thanks for replying. I appreciate it.
Yes, i am using the new LG OLED G3 Plex App. I also have an NVIDIA Shield, but I find playing from the LG Plex app provides a smoother play experience.
Thanks for sharing those other threads, it def confirmed it seems to be a bug with the player.
I will track those threads. Thanks!
Same happening here too. I’m using unRaid with the latest Plex server version.
How to fix this?
Jul 4 16:45:34 kernel: Plex Transcoder[34287]: segfault at 28 ip 0000145da844ad02 sp 00007ffcf1bb21b0 error 4 in libavformat.so.59[145da82ca000+1fe000] likely on CPU 16 (core 4, socket 1)
Jul 4 16:45:34 kernel: Code: 89 ef e8 f1 a8 07 00 45 31 ed 85 c0 41 0f 94 c5 45 85 e4 74 60 83 bb 80 05 00 00 00 74 57 48 8b ab 70 05 00 00 48 89 6c 24 08 <48> 8b 7d 28 e8 65 a5 07 00 eb 62 48 8b bb 80 00 00 00 8b 93 7c 05
Many of my friends are complaining about this, and yes they are using subtitles.
