Plex tv agent and thetvdb not matching
Server Version#: 1.24.2.4973
Player Version#: 4.62.1
Migrating to the new plex tv agent and noticed that the specials in the show “Fairy Tail” don’t match up with thetvdb. What can i do to get this fixed?
Did you set the “episode order” of your library to TheTVDB?
yes when i go to edit library and look at the advanced tab the ordering is set to theTVDB
Seems to all be there. Which episodes are mis-matching?
Also is the episode order on the show set to TVDB Aired order (or Library Default)?
I was using Library Default. when i switched it to oldest first and refreshed the metadata, the specials mapped properly. What is library default? Newest First?
No that’s not Episode Sorting which is different to Episode Order :sweat_smile:
Episode Order is a bit futher down and it’s where you can change between ordering (TVDB absolute, aired, etc). It must be set to Library Default or TVDB (Aired) for Specials to generally match.
I suspect the metadata refresh just fixed your issue though. Changing the sorting wouldn’t affect the matching.
