Plex.tv/link not generating code on samsung smart tv
Offcourse, if your PMS is on same network , you can view everything, proxy is only needed for remote servers
and for multiple users with plex pass :wink:
happy note: i have a working fix now. cleaning the code right now, after that a new release of the proxy will be available
please use version 0.3.0 of the proxy, located here:
Verified and working on E-Series. Please report back if this also works on F-Series and H-Series
Happy (early) X-Mas :slight_smile:
Really nice job, and thnx for supporting us!!!
Alles gut… ich habe die Apps auf den Samsung TV’s gelöscht… nutze ich jetzt nicht mehr.
Habe ja geschrieben, wie ich es weiterhin mache.
Einmal über FireStick und einmal über die XBOX… notfalls geht auch DS Video von Synology.
Auch allen ein schönes Weihnachtsfest gewünscht.
Worked perfectly on my H-Serie
Hola , Alguien puede pasarme en limpio como utilizar este procedimiento, para poder vincular un smartv samsung que no resive el codigo?
English please
dice foro en Español!
Traduccion: Hello, Can someone tell me how to use this procedure, to be able to link a samsung smartv that does not resive the code?
You can use offline method… If you really need to be online , use the proxy, the readme is on the GitHub page
1_ I did not understand, what is each one for?
2- It is for remote connection
3-the download link is this? "Release Fixed redirect problem for Plex-Linking · kadrim/proxy4plex · GitHub "
Thank you!
Hi, the documentation is here:
Was struggling to figure it out on my J series after the app randomly stopped working and would hang on the code screen after reinstall.
Offline method:
  1. On PMS add TV’s IP to Settings → Network → List of IP addresses and networks that are allowed without auth
  2. Launch Plex App and when it hangs on code screen hit the Menu button to bring up the on screen keypad. Choose the red “A” to select “Home.”
That should give the option to manually add the server’s IP, which bypasses the auth so you don’t have to enter the code.
Replying just for those that are confused on how to get to the settings as I was.
@one_dnasty
thank you very much !!! I tried the offline method and it works fine on my TV samsung.
Great job !! I’m really impressed :clap:
I do not finish knowing if it works for remote connections?
Hello, I have the same problem. My old smart TV is U32J5500. I try with USB key but when I insert to the TV nothing append. I try to sideload, but in smart hub, the red button don’t work. I really need the online function.
Please help me.
Thanks.
Sorry for my English
thanks for this. I have tried it, entered the remote Plex server IP address:port and get the following:
Test failed, server is reachable but it returned: ‘Access is denied’. Due to the security settings, this server is only accessible, when you are logged in on your Plex account.
I’ve added my home IP ranges to the allowed without auth field on the remote server.
Which means most likely, that you have set Secure Connections to “required” in your server’s settings.
You cannot require secure connections if you are connecting a client without login, just by server IP address.
thank you for the very quick reply Otto. I have secure connections set to Disabled (previously Preferred), and the issue persists.
Is there a setting somewhere that requires a logged in Plex account?
Is above in private address space?
What syntax did you use in PMS settings to allow without auth?
Mine is 192.168.1.0/255.255.255.0
And a PMS restart is needed afterwards
thank you.
The IP address is public and fixed. I’m using the same syntax as you, and have also tried it without the subnet. I can verify from the remote server console that the server is seeing that IP address from other (working) devices from within my house.
I can even see the request that hitting the “add Server” button from the Samsung client makes (verbose logging on).
Request: [MYIPADDRESS:41368 (WAN)] GET / (12 live) GZIP Signed-in / Accept => application/xml, text/xml, /; q=0.01 / Accept-Charset => iso-8859-1, utf-8, utf-16, *;q=0.1 / Accept-Encoding => gzip, deflate / Accept-Language => en-GB / Connection => Keep-Alive / Host => PMSADDRESS:42412 / User-Agent => Mozilla/5.0 (Linux; Tizen 2.3; SmartHub; SMART-TV; SmartTV; U; Maple2012) AppleWebKit/538.1+ (KHTML, like Gecko) TV Safari/538.1+ / X-Plex-Client-Identifier => UNIQUEID / X-Plex-Client-Platform-Version => 5.1 / X-Plex-Device => Samsung TV / X-Plex-Device-Name => TV UE48JU6000 / X-Plex-Language => en-US / X-Plex-Model => UE48JU6000 / X-Plex-Platform => Samsung / X-Plex-Platform-Version => 5.1 / X-Plex-Product => Plex for Samsung / X-Plex-Provides => client,player,pubsub-player / X-Plex-Version => 2.012
(replaced MYIPADDRESS, PMSADDRESS, UNIQUEID)
related response
Completed: [MYIPADDRESS:41440] 401 GET / (11 live) GZIP 0ms 435 bytes
