Server Version#: 1.29.1.6316
Player Version#: 4.87.2
I am trying to map the show “The Berenstain Bears”. The Plex TV Series Agent will only ever find a series from 1985. Both TVDB and TMDB have a series from 1985 as well as 2003. The episodes I have are from the 2003 series.
I have named the series folder with the tvdb id:
Berenstain Bears (2003) {tvdb-72502}
It will refuse to match to the 2003 series, and only matches to 1985. Going into the Fix Match menu, which is what I typically will do, will only ever return the 1985 series.
If I switch the library agent to TVDB, it is able to find both series years and if I select 2003, it downloads the Episode titles and metadata perfectly. I can also select the TMDB agent, and it can also find the series correctly and shows both 2003 and 1985.
But if I switch the library agent back to Plex TV Series, it reverts back to the 1985 series.
Is my only option to use the TVDB agent going forward?
