Hey Guys, My plex tv show titles are not showing up for star wars: the clone wars, season 6 works properly, however, the other seasons are not. I think it has something to do with the embedded titles that I accidentally ripped with. It says Star Wars: The Clone Wars: S5 Disc 1 for every episode in season 5. I do not know how to remove this, I tried to remove them in windows by opening properties and removing the title in details but it still shows up as those weird names. I have moved the folder, refreshed and deleted trash then moved it back but nothing. Any help would be great!
Are you using side car artwork for any of your files? If not the easiest thing is to go to the the agent settings and move “local media assets” below tvdb. That way it will prefer tvdb data over the local embedded metadata
Thank You! Worked Great, Set that setting and all of the episodes are correct! You are a lifesaver!!!
